496 dieseling when shut off - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 19th, 15, 06:31 AM Thread Starter
Exclamation 496 dieseling when shut off
I just read 100 threads on dieseling and I feel I have everything adjusted and 496 still diesels at shut off. The timing is set at 13-14 initial with 39-40 total and no vacuum advance on MSD distributor. I have the car idling at 800 rpms. This is the first time ever using a speed demon carb, it's an 850cfm. Idle screw are 1.25 turns out. Not sure on the secondary side how far the blades are open. I read there is also a idle screw in center of carb under air cleaner stud is.
What should I check now to get dieseling to stop. The 496 has large solid roller as well.
Thanks, Erik
67 Camaro Pro Street, 540 Bill Mitchell Merlin big block, Merlin Aluminum heads, Holley 870, hydraulic camshaft, 2" Hooker Super Comp headers, Mallory and Crane ignition system, TH400, 2600 stahl, Ford 9" w/ 4:10 gears and posi.
Erik Beckett is offline
post #2 of 10 (permalink) Old Apr 19th, 15, 08:07 AM
DT
Donny
DT's Avatar
Re: 496 dieseling when shut off
What is the compression of the engine ??? Are you using Premium gas 93 octane or better ?
DT is offline
post #3 of 10 (permalink) Old Apr 19th, 15, 12:38 PM
ds1
Dan
Could be a vacuum leak somewhere
ds1 is offline
post #4 of 10 (permalink) Old Apr 19th, 15, 04:51 PM
Lonnie
Lonnie P's Avatar
Mostly it is octane & idle speed related.
The higher your idle speed, the less the engine is choked off & the higher tendency to want to run on.
Typically is can be overcome with higher octane fuel.
You ignition timing settings has nothing to do with it, as once you turn the key off there is no spark.
Assuming you mean your vacuum advance is not connected, but present... You may be able to hook up the vacuum advance to manifold vacuum. This will make the engine want to idle faster due to the additional timing at idle. Correspondingly you can then back out the idle speed screw to get the idle back to your original setting. This will help to choke off the engine when you turn it off.
Lonnie P is offline
post #5 of 10 (permalink) Old Apr 19th, 15, 05:24 PM Thread Starter
No vacuum advance on distributor. MSD billet ready to run. This is a 9.8.1 motor by what previous onwer stated. took carb off today and reset it to factory specs. The front and rear butterflies needed to be set the same and they weren't but they are now.
I am running 93 in it. I will bump timing back up to 14-16 and play with carb some. I assumed with the higher timing the idle screws would not have to be out as much. Also the float bowls were at there highest setting so I lowered them as well.
Thanks, Erik
post #6 of 10 (permalink) Old Apr 19th, 15, 05:39 PM
R/T
Jack
Erik
Do you have a MSD ignition box ?
Matthew 22: 37-39
R/T is offline
post #7 of 10 (permalink) Old Apr 19th, 15, 06:00 PM Thread Starter
Yes, 6AL box and msd coil
post #8 of 10 (permalink) Old Apr 19th, 15, 06:25 PM
R/T
Jack
https://www.msdignition.com/WorkArea...id=15032386116
Go to page 8
Maybe this will help...
Matthew 22: 37-39
R/T is offline
post #9 of 10 (permalink) Old Apr 19th, 15, 07:17 PM
Lonnie
Lonnie P's Avatar
If the engine can withstand more initial timing, it should help the situation.
Just be sure adjust the centrifugal advance to keep the total from getting too high.
Lonnie P is offline
post #10 of 10 (permalink) Old Apr 19th, 15, 08:38 PM
Anne
Did you go through the detailed setup directions ?
http://www.demoncarbs.com/Assets/doc.../LIT350rev.pdf
I noticed this comment :
Due to the choke horn's increased airflow design, and dependent on what air
cleaner/air cleaner gasket combination is used, a slight dimple in the air cleaner
may be necessary to allow for the butterfly to have a complete range of motion.
Failure to do so could result in a vehicle with an increased idle that could make the
vehicle hard to stop or control.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
