Re: Holley Bog
If it happens at WOT I would say increase the squirter size. Your symptoms tell me the accelerator pump isn't providing any fuel for that first fraction of throttle movement. Pull the air cleaner off and just barely move the throttle. I'm not talking 1/8th or 1/16 throttle, I mean where the throttle blades just start to open. At this slight throttle opening it probably won't squirt but you should see some fuel come out.
You might want to buy a Holley Trick Kit. Comes with a bunch of gaskets, squirters, pump cams, power valves, etc. along with tuning instructions.
