LQ9 questions - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 19th, 15, 01:46 PM Thread Starter
DT
Donny
DT's Avatar
LQ9 questions
Hey guys,
I have to admit I am old school. Having said that, I was looking at LQ9 engines for an LS swap down the road. What intake you guys install on these engines?? I think they all have TB ?? Also what about the pulleys etc ?? If I change the cam, where can I send out the ECM to be calibrated for the new cam etc ?? Thanks.
DT is offline
post #2 of 10 (permalink) Old Apr 19th, 15, 02:11 PM
Brent
67Rally's Avatar
Re: LQ9 questions
The LQ9 is a good motor. 6.0l with higher compression than the LQ4. If you keep the cathedral port heads, you can run an LS6 intake (better) or LS1 or LS2 intake. Or you could do an aftermarket like a Fast intake. If you change heads, you could do an LS3 intake. Yes, they all have a TB.
I'm running a Vic Jr. intake with a 4 barrel TB to keep an old school look.
I went with a whole new wiring harness from PSI conversions, they will flash their ECU as well.
67Rally is offline
post #3 of 10 (permalink) Old Apr 19th, 15, 02:30 PM
Re: LQ9 questions
LQ9 10:1 comp but otherwise same as the LQ4 (9.4:1 due to dished pistons)
I got a LQ4 for a song that needed a rebuild. It had no wiring and was complete intake to pan. Beings I didn't have the electronics and can tune a carb... I went with a carbed intake and used a MSD box to drive it.
I swapped to LS3 heads that I had the shop shave to get the comp up (10.5:1ish), added a cam on a 110 LSA due to the carb, and it performs
Not knocking EFI, but if you don't have the parts...it can get expensive.
With that said, there are a few guys that can fix the wiring by removing the VATS and such.
As for where to send the brain (ECM), I'm at a loss, but there are people that can do that too
68 Camaro~LSx ~all motor
post #4 of 10 (permalink) Old Apr 19th, 15, 02:38 PM Thread Starter
DT
Donny
DT's Avatar
Re: LQ9 questions
Thanks guys for the info, really appreciate it !!
DT is offline
post #5 of 10 (permalink) Old Apr 19th, 15, 03:33 PM
the BOSS&Ralph
Re: LQ9 questions
To avoid needing support for re-flashing I went with Megasquirt for the LS3 I'm putting in a '69 Vette.
friendlyviper is offline
post #6 of 10 (permalink) Old Apr 19th, 15, 04:56 PM Thread Starter
DT
Donny
DT's Avatar
Re: LQ9 questions
What is Megasquirt ?? UPDATE: I just looked into Megasquirt. Good stuff, thx!
DT is offline
post #7 of 10 (permalink) Old Apr 19th, 15, 09:05 PM
the BOSS&Ralph
Re: LQ9 questions
I ordered mine last week. I'll be working with a generic harness but they said that they are working on a plug/play LS harness.
post #8 of 10 (permalink) Old Apr 20th, 15, 03:38 AM
Re: LQ9 questions
There's a new player out there also....Dayton Sensors. I hear good things about them, but no personal experience.
Also, not sure if its carb swap or EFI only
post #9 of 10 (permalink) Old Apr 20th, 15, 07:24 AM
Vega$69's Avatar
Re: LQ9 questions
You can simply run an LS2 intake, fuel rails, and injectors. (Can buy for about $300 - $400) which is way less then a new 4 barrel intake and carb.
Even when you buy the harness and ECM for EFI you'll still be less.
For Carb you need spark control and tranny controller if going auto.
The ECM does engine and tranny control
PSI is a good way to go for the harness and ECM.
With a cam swap you best to have it dynotuned when you get it all together.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #10 of 10 (permalink) Old Apr 20th, 15, 08:00 AM Thread Starter
DT
Donny
DT's Avatar
Re: LQ9 questions
Thanks again everyone.
DT is offline
