Random misfire while cruising - Team Camaro Tech
post #1 of 15 (permalink) Old Apr 19th, 15, 10:15 PM Thread Starter
Chaz
Yesterday I noticed my car bucking/misfiring at highway speed, around 70-75. My tach needle would also jump like crazy. WOT is fine and idle is fine.
So far I'm thinking bad coil, bad wire, or bad plug. Up till now ,it's ran fine! This was also sporadic. It would act up like that then be fine for 20 miles.
I already ordered new wires, a new coil, and some better wire retainers which mount to the valve covers.
I have a Mallory ignition setup, aed 750 carb, roller cam, edelbrock etec 200 heads.
68 Camaro
Some mods...
68SSlemans is offline
post #2 of 15 (permalink) Old Apr 19th, 15, 10:36 PM
Steps
Re: Random misfire while cruising
1st thing that says is the primary ign circuit has a loose connection... ie the ign wires to the coil..
if the tach dosent jump the issue is after or in the coil.. or HT side
this also indicates loose wire....a plug or coil general is consistent.. or in other words once it has sucked a kumura thats it it doesnt work right...or not at all
Steptoe is offline
post #3 of 15 (permalink) Old Apr 19th, 15, 11:11 PM
mike
Check the cap, especially the carbon ball, ask me how I know. lol
bigblockragtop is offline
post #4 of 15 (permalink) Old Apr 20th, 15, 10:51 AM Thread Starter
Chaz
I will check all these things. The ignition wires to the coil are good and tight... A few months ago i made a homemade tach filter.... don't think it should have too much to do with this but will check all those connections as well.
68 Camaro
Some mods...
post #5 of 15 (permalink) Old Apr 20th, 15, 10:57 AM Thread Starter
Chaz
Kumura? I'm confused
68 Camaro
Some mods...
post #6 of 15 (permalink) Old Apr 20th, 15, 11:36 AM
How to Understand a New Zealander:
http://www.lonelyplanet.com/new-zeal...articles/76787
And from another site:
Knackered, Tit's up, Sucked a kumara
3 phrases all rougly meaning that something is not working i.e. a possible real scenario could be "Yeah, the car's knackered, the whole day has gone completely tit's up - man, it sucks a kumara!".
We might say something "has given up the ghost"
Is that about right Steps?
trland is offline
post #7 of 15 (permalink) Old Apr 20th, 15, 12:07 PM
George
Gbauer's Avatar
...I'm still not sure I understand...
Kiwis....
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #8 of 15 (permalink) Old Apr 20th, 15, 12:37 PM Thread Starter
Chaz
In California would just say it f#%^ed up LOL
68 Camaro
Some mods...
post #9 of 15 (permalink) Old Apr 20th, 15, 01:02 PM Thread Starter
Chaz
it almost feels like a lean surge from the carb but why would the tach needle start bouncing everywhere?
68 Camaro
Some mods...
post #10 of 15 (permalink) Old Apr 20th, 15, 01:22 PM
Karl
VetteFreak's Avatar
Check the rotor and cap...might be corroded or cracked!
Karl / VetteFreak
69 Camaro RS 350/350TH...Burgundy...711-Black Int/Houndstooth Seats
2007 Corvette Conv. LS-2/A6...Monterey Red/Black Top & Int
VetteFreak is offline
post #11 of 15 (permalink) Old Apr 20th, 15, 01:53 PM Thread Starter
Chaz
Yea i'll check the cap and rotor... didn't even check because they're only like a year old. I think it's a coil problem. Sitting at the light the other day the car just shut off. I read on the Mallory site that this is a symptom of a coil headed south.
Thanks for the advice. I'll let everyone know what I find!
68 Camaro
Some mods...
post #12 of 15 (permalink) Old Apr 20th, 15, 08:56 PM
mike
Even though the cap is fairly new check it. Sometimes moisture can corrode the carbon ball causing misfires especially while low rpm cruising. This happened to me twice now. I got an ugly brown Accel cap and hope this stops the problem.
post #13 of 15 (permalink) Old Apr 21st, 15, 09:47 AM Thread Starter
Chaz
will do. I'll order a cap and rotor kit too. I just found out Mallory was bought out by MSD and will no longer be producing parts
68 Camaro
Some mods...
post #14 of 15 (permalink) Old Apr 21st, 15, 02:17 PM
Steps
yep its knackered.. stuffed....
the tach is the give away.. it runs on the primary circuit.. ie it counts each time the electronic 'points' open and close....so if there is an issue here then the tach will jump around/ momentary die.
If the issue is in the secondary circuits ie cap rotor spark plug HT leads.. the tach will not momentarily die or jump around .....
And as mentioned the primary circuit (which goes from the battery right thru to the coil) was been resently messed with...before that no issues.
Steptoe is offline
post #15 of 15 (permalink) Old Apr 21st, 15, 04:04 PM Thread Starter
Chaz
yes no previous issues with this. The car was in the body shop recently getting the driver's side rocker panel redone. I noticed they had to jump the car several times. I read on the mallory site that jumping the car can damage the coil...
68 Camaro
Some mods...
