Exhaust clamps Flat Band - Team Camaro Tech
post #1 of 11 (permalink) Old Apr 21st, 15, 01:43 PM Thread Starter
Lyle
I have bought a new exhaust system for my car. The Headers are Doug's D320 and the pipes are Flow Master Delta Force 17201 3". The flow master clamps look like they will deform the pipe like a traditional clamp and I was thinking about using Stainless steel flat band or step clamps. Has anyone had good or bad experiences with these. I have read on amazon that some people complain and others love them. It would be nice to be able to remove the exhaust easily as I don't have a lift.
I was also curious if anyone has a BBC with a TH400 and a gear vendor for proper H pipe placement. I don't have a gear vendor yet but I will. and hate to redo the exhaust if I can help it.
69 X66 72 72
akwolf is online now
post #2 of 11 (permalink) Old Apr 21st, 15, 06:41 PM
Re: Exhaust clamps Flat Band
I use the formed flat band clamp for the reason you mentioned.
This is just a sample of what is out there. I used them on all my flowmaster pipe fittings and muffler.
http://www.summitracing.com/parts/sum-692250/overview/
TC # 349
zdld17 is offline
post #3 of 11 (permalink) Old Apr 21st, 15, 08:56 PM Thread Starter
Lyle
Thank you. Did you put any sealant in the joints or is it not necessary.
69 X66 72 72
post #4 of 11 (permalink) Old Apr 21st, 15, 09:13 PM
Garth
I use them, no complaints. If you have joints with stress you may need to tack weld them so they don't rotate worst case. No sealant needed.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
69L48Z27 is offline
post #5 of 11 (permalink) Old Apr 21st, 15, 09:45 PM
Steve69SS396's Avatar
I used these on my 3-1/2" exhaust. No sealer, and they work great.
http://www.summitracing.com/parts/wlk-33223
Steve69SS396 is offline
post #6 of 11 (permalink) Old Apr 22nd, 15, 02:33 AM Thread Starter
Lyle
I was tempted to tack weld the mufflers to the pipes but I will see if they look skookum when I intall them. Thank you for the info. I hate buying stuff and not having it work.
69 X66 72 72
post #7 of 11 (permalink) Old Apr 22nd, 15, 06:06 PM
Send a message via AIM to Satatic
I have 4 of them on mine. I stepped down from 3.5 to 3 right at the header. So i have a 3.5 lap joint band clamp there. The reducer fits over the collector. Then I did a 3 inch butt joint after that. Then the rest of my exhaust is all welded together dumped before the axle.
I have no interest in the crush style clamps.
Satatic is offline
post #8 of 11 (permalink) Old Apr 24th, 15, 05:45 AM
I used the flat clamps on my 3" flowmaster exhaust and they work well. I also have a big block with the turbo 400 with the 4" tail shaft housing and just recieved my gear vendor unit but haven't installed it yet. The h pipe will have to be moved rearward for sure so I would hold off before installing your exhaust system.
Jim & Yvonne
1968 Camaro
468 BBC, Turbo 400, 4.10 12 Bolt.
2010 Camaro SS/RS, Black on Black Leather
2008 GMC Crew Cab 4x4, LMM Duramax, Allison 6 Speed,
6" Cognito Lift, 35" Nitto's
Ledfoot is offline
post #9 of 11 (permalink) Old Apr 24th, 15, 06:29 AM
When I replaced my old Black Jack aluminized headers with a new set of Dynatech ceramic coated headers, the collectors were of a completely different design, so I ended up cutting the old Black Jack collectors off the front pipes which were welded on and did a butt joint using a stainless steel flat band clamp. The mechanical joint was fine and there was no audible exhaust leak, but there were signs (carbon/soot) of minor exhaust leaks taking place. I cut a couple of short 1" long stub pipes that fit snugly inside the 2.5" front pipe and collector stub that span the butt joint internally and that eliminated the minimal carbon/soot leaks that were visible.
I wish someone manufactured reasonably priced exhaust flanges that could be welded to the end of pipes as an alternative (my H pipe uses these between each of the front pipes), but the band clamps do work well and allow the pipes to later be separated and removed when necessary, for me that is any time the transmission needs to be removed and replaced.
NH69Z28RS is offline
post #10 of 11 (permalink) Old Apr 24th, 15, 05:33 PM
Carbon seal. No sealant. Say Hi to Sara .
TC # 349
zdld17 is offline
post #11 of 11 (permalink) Old Apr 24th, 15, 11:36 PM Thread Starter
Lyle
Clamps and Jet hot coat exhaust
Hope I dont have too much carbon. I used to work for a diesel manufacture as an engine and generator mechanic and they did form quite the carbon seal. If it leaks now it wont soon.
Ya I dont see Sarah arround town. I see Tod occasionaly but I think they are better left alone to try to live a normal life at home.
Jim (Lead Foot)
I would love to get some measurments on where to place my H pipe. I wont be buying the gear vendor this year and will need to install my exhaust before going in to the body shop for the rest of the work and paint. I cant wait for your report on the gear vendor. Our cars are about the same. I have 3.73 rear gears with 275 60 15 tires.
Thanks for the info on the flat band clamps I will order a set.
Has anyone thought about jet hot coating their entire exhaust? I got a quote for $540.00 to have it done to my flowmaster 3 inch. I wanted stainless but wasnt offered by flowmaster. The exhaust was about 700 I think. Thats getting spendy.
69 X66 72 72
