PCV valve - Team Camaro Tech
post #1 of 18 (permalink) Old Apr 21st, 15, 07:03 PM Thread Starter
ken
PCV valve
when I cleaned up my motor in my 1967 327 I changed the valve covers. The PCV valve was in the passenger side valve cover and ran to the carb. The new valve cover has the same looking grommet in it and The PCV valve goes in but not far enough it hits a metal plate that I assume is a baffle but so any ideas on what I can do to make the PCV valve fit ?
1967 Camaro RS convertible 327 eng
pasthelp is offline
post #2 of 18 (permalink) Old Apr 21st, 15, 07:18 PM
jared
Re: PCV valve
Look at the gourmet. Sometimes there not cut out all the way Through
jcfcamaro is offline
post #3 of 18 (permalink) Old Apr 21st, 15, 07:25 PM Thread Starter
ken
Re: PCV valve
No I can see what it is hitting it is a plate
pasthelp is offline
post #4 of 18 (permalink) Old Apr 21st, 15, 07:31 PM
jared
Re: PCV valve
Is the other cover the same. That's weird never heard of that happening.
post #5 of 18 (permalink) Old Apr 21st, 15, 07:36 PM Thread Starter
ken
Re: PCV valve
yes exactly I put a air breather on that one
pasthelp is offline
post #6 of 18 (permalink) Old Apr 21st, 15, 07:41 PM
jared
Re: PCV valve
Normally the baffle is pretty deep. Any pictures
post #7 of 18 (permalink) Old Apr 21st, 15, 08:21 PM Thread Starter
ken
Re: PCV valve
its hard to get a picture of how deep the baffle is depth perception with the pictures I have taken is very hard to see
pasthelp is offline
post #8 of 18 (permalink) Old Apr 21st, 15, 08:22 PM
jared
Re: PCV valve
I'd say send them back or get new ones
post #9 of 18 (permalink) Old Apr 21st, 15, 08:30 PM
Anne
Re: PCV valve
Is the pcv valve inserted through a rubber grommet ?
Maybe a thicker grommet would help ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #10 of 18 (permalink) Old Apr 21st, 15, 08:33 PM Thread Starter
ken
Re: PCV valve
A thick grommet that held it tighter would hold it in place but it would still be sticking half out of the cover
pasthelp is offline
post #11 of 18 (permalink) Old Apr 21st, 15, 08:34 PM
Re: PCV valve
I had the same problem with a set of old school Mickey Thompson valve covers. The PCV valve bottoms out on the baffle/plate, blocks the valve and the engine runs bad.
I went to the hardware store and bought some clear tubing that was the same inside diameter of the PCV valve. Lets says that 3/4 of an inch normally goes into the grommet but yours only allows 1/2 an inch and it bottoms the valve on the baffle/plate. Cut a piece of tubing that is 3/8ths of an inch, this will allow you to put the PCV valve in the grommet and allow 1/8 of an inch clearance between the baffle/plate and the valve. Works like charm.
Good luck with your project
MJK-4 is offline
post #12 of 18 (permalink) Old Apr 21st, 15, 08:39 PM Thread Starter
ken
Re: PCV valve
here is a photo
pasthelp is offline
post #13 of 18 (permalink) Old Apr 21st, 15, 08:40 PM
Anne
Re: PCV valve
Or if the PCV valve is 3/4" dia, why not drill a 1/2" hole in the baffle plate ?
Let the valve rest against it and it won't be blocked.
Ronald Reagan
post #14 of 18 (permalink) Old Apr 21st, 15, 08:40 PM Thread Starter
ken
Re: PCV valve
thanks
pasthelp is offline
post #15 of 18 (permalink) Old Apr 21st, 15, 08:42 PM Thread Starter
ken
Re: PCV valve
that would probable be the thing to do im just feeling kind of lazy I have the valve cover on the car and I like the fit I hate to take it off. before I do anything I think I will hang it up for the night before I do something half ***
pasthelp is offline
