Edelbrock Performer RPM with Cowl Induction Hood - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 24th, 15, 05:16 PM Thread Starter
James
I would like to use an Edelbrock Performer RPM 2-0 intake with my 1969 Big Block Cowl induction Hood Setup. Anyone else used this manifold with factory air cleaner? Will I need to modify or purchase a drop base air cleaner for it to work? The carb pad height is 5.22". All responses will be greatly appreciated.
Yenklone is offline
post #2 of 10 (permalink) Old Apr 25th, 15, 03:40 AM
Re: Edelbrock Performer RPM with Cowl Induction Hood
James, you'll find through a quick search in the engine section that this topic has been discussed a lot. Yes, you'll require a drop base ...
Cheers
69' SS/RS X11 PRO-TOURING E-FORCE LS7, DSE Sub, T56 MAG, Recaro, Wilwood disc, Racepak IQ3S, SpeedTech TA/JRI CO's, Pro-Venom 250s, Forgeline CV3C 20/19 - SOLD
Sheck44 is offline
post #3 of 10 (permalink) Old Apr 25th, 15, 05:06 PM
Andy
That's the same combo that I have on my car. No problems with 3310 carb and factory cowl air cleaner.
A Schab is offline
post #4 of 10 (permalink) Old Apr 28th, 15, 06:38 PM Thread Starter
James
A Schab, I need to order manifold because engine will be ready for run in soon. Are you using this manifold? see link: http://www.summitracing.com/parts/edl-7161
Thanks for all your help!
Yenklone is offline
post #5 of 10 (permalink) Old Apr 28th, 15, 06:47 PM
DT
Donny
DT's Avatar
I'm using a Performer RPM with a Holley 4150 and an SS hood. Dropped base of course.
DT is offline
post #6 of 10 (permalink) Old Apr 28th, 15, 08:48 PM
Andy
That's the one that I have.
A Schab is offline
post #7 of 10 (permalink) Old Apr 29th, 15, 06:07 AM Thread Starter
James
I'm a bit confused about drop base air cleaner assemblies. Where can I buy one?? Do they maintain the same appearance as original cowl air cleaner assembly?
A Schab, can you share a picture of your engine with Edelbrock RPM setup? are you using the stock air cleaner setup with seal on top?
Thanks in advance for your responses
Yenklone is offline
post #8 of 10 (permalink) Old Apr 30th, 15, 04:23 AM
James, exact same size and shape as OEM but with much better air flow as the lower you go on the base the more restricted the flow.
Sheck44 is offline
post #9 of 10 (permalink) Old Apr 30th, 15, 07:58 AM
Doug
James, Check out Summit Racing they have this 1" dropped base air cleaner or you can get a 1.5 dropped base air cleaner without the Chevrolet logo. http://www.summitracing.com/parts/na...2080/overview/ The 1.5 drop http://www.summitracing.com/parts/spe-4915/overview/
Cdminter55 is offline
post #10 of 10 (permalink) Old May 5th, 15, 04:36 PM Thread Starter
James
Thanks for all replies and pictures but I would prefer to use factory air cleaner. Anyone know if it will work with Performer RPM??
Yenklone is offline
