What breather fits original stock 350 covers? - Team Camaro Tech
post #1 of 6 (permalink) Old Apr 28th, 15, 08:56 PM Thread Starter
Tony
I looked at 3 stores and couldn't find a push in that would fit. I wanted a k&n but was open to any. Hole in cover is small...about 3/4-1 inch diameter.
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #2 of 6 (permalink) Old Apr 28th, 15, 11:07 PM
Vintage 68's Avatar
Thumbs up Re: What breather fits original stock 350 covers?
K&N makes their small push-in type breathers in many sizes from 3/8" up to the 1.22" stock GM size.
I often use the 3/4" for marine applications with the small valve cover holes - their part no. 62-1160.
I also have used their unit for stock Chevy valve cover with a 1.22" hole size - part no. 62-1490.
If your local parts house can't order you can get from Summit or Jegs.
Hope this helps.
1968 Convertible
Some trucks
Vintage 68 is offline
post #3 of 6 (permalink) Old Apr 28th, 15, 11:13 PM Thread Starter
Tony
Yes thank you
TClovis is offline
post #4 of 6 (permalink) Old Apr 29th, 15, 07:56 AM Thread Starter
Tony
Hope this helps.
I bought the 62-1160 from Summit. Do you know what grommet fits that cover and breather? I just have a hole to fill in valve cover.
TClovis is offline
post #5 of 6 (permalink) Old Apr 29th, 15, 08:34 AM
George
Gbauer's Avatar
I was able to buy a breather locally. You might need to look in another aisle for the grommet.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 6 (permalink) Old Apr 29th, 15, 07:43 PM
Vintage 68's Avatar
Originally Posted by TClovis View Post
I bought the 62-1160 from Summit. Do you know what grommet fits that cover and breather? ...
I find the grommet is dependent on the type and manufacture of the valve cover.
The OEM stamped covers will usually take the Dorman #42323, but the #42321, 42333 or 42052 types are often also usable,
The aftermarket vary due to stamping type/material type/hole size they used in construction.
I also find the #42062 is useful for OEM look when plumbing the fresh air intake for a air filter source set-up.
These can often be found at you local auto parts stores under the "HELP" brand.
1968 Convertible
Some trucks
