433 Small Block-Recommendations? - Team Camaro Tech
post #1 of 7 (permalink) Old Jul 12th, 03, 11:25 AM Thread Starter
Tim
I had planned to rering/new bearings on my existing 400 small block chevy, but at the machine shop-nice crack in the lifter valley was located. Bummer, as it only had about 7000 miles on it.
I have another block, but think moving up to a forged rotating assembly may be better move at this point. The old assembly was OEM 400 with forged pistons.
Scat offers a reasonable 4 inch 4340 crank and H beam rods. Not sure what pistons are included nor compression.
Haven't bought the heads, but they will be AFR 210's.
Use will be street car with EFI-tremec, 4.10, and small nitrous.
Any negatives with going with a stroker in a 400 block? Do the oil support rings leak abnormally high levels of oil? Will I hit coolant jackets when grinding the crank clearance?
433 would be neat, but simple 406 would be nice too....or even one that runs period... [img]smile.gif[/img]
1969 Nova SS 350
EFI 407/TKO600/4.11
11.43 at 121 MPH
L48M20 is offline
post #2 of 7 (permalink) Old Jul 12th, 03, 06:04 PM
there is always a chance of grinding into the water jackets. my oppion (for what it's worth) is to go with an aftermarket block if at all possible... the reason being that the stock 400 blocks are not all that strong. about 500hp is all they can stand plus the added stress of nitrous i think your just going to shorten the lifespan of a fairly expensive investment. just my 2cents
bottle baby is offline
post #3 of 7 (permalink) Old Jul 12th, 03, 10:23 PM
Sean
if you do go the stock block route, i'd reccomend half filling the block with block fill. this makes the bottom end more ridgid and takes some of the water jacket fears away. an aftermarket block is definately the ticket though with larger than normal cubes, imo, if cash is not an issue. i'd do it, my next motor will be a 427+ small block as well, but my 406 is still serving well. it depends on what you want out of it, a 406 can make plenty of horsepower as well. i like your head choice, and scat i believe offers srp pistons in thier kits, which i highly reccomend. good luck with it at any rate [img]graemlins/thumbsup.gif[/img]
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 7 (permalink) Old Jul 12th, 03, 11:52 PM
All things considered, I'd have to recommend an aftermarket block with anything over 406 or 408, especially with nitrous.
Toby Keen is offline
post #5 of 7 (permalink) Old Jul 13th, 03, 07:22 AM
Carl
Dart Little M....
CarlC is offline
post #6 of 7 (permalink) Old Jul 13th, 03, 10:30 AM Thread Starter
Tim
Jeez! You guys are convincing me to chintz out... [img]smile.gif[/img]
I have yet to hear for sure, but my OEM crank should be good along with my 5.565 rods and Speed Pro 2256 pistons. I like the pistons as they are 12.5 dish which will give me 10.4 to 1 with the 67 cc AFR 210 heads that are readily available.
I just figured if I'm going to invest machine work in a virgin block to no do it to my used rotating assembly (less than 7000 miles).
Aftermarket block isn't a player for my plan so...
Thanks for the inputs really. I'm going to have mucho fun with it whether it is a 406 or a 433.
L48M20 is offline
post #7 of 7 (permalink) Old Jul 13th, 03, 01:34 PM
i would at least use a 5.7 rod the shorter rod will shorten the ring life
