Crate recommendation - Team Camaro Tech
post #1 of 8 (permalink) Old May 2nd, 15, 01:58 PM Thread Starter
I want to get a crate motor for a 79Z28 and would like some recommendations. I have a budget of 4k and have looked at companies like blueprint, year one, and phoenix engines. Have read good and bad with all of these. Looking for 400hp/400ftlb , i also have a company called AES in elk grove IL local to me that also sells a crate. Does anyone have any input on this. I side toward a vortec engine with roller cam/rockers.
maddart is offline
post #2 of 8 (permalink) Old May 2nd, 15, 02:10 PM
Keith
Re: Crate recommendation
Crate engines are all the rage right now 9and often tough to beat for the money), but i would recommend talking with a local machine shop, and seeing what they can build for you...
if you can find a reputable shop, i think your goals are very easily do-able locally, and you always have someone to go back to if their is a problem...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #3 of 8 (permalink) Old May 2nd, 15, 02:12 PM
A buddy just bought a ZZ4 and I spec'd a cam for him...real happy so far, drives/runs/pulls great....no track times yet.
Another buddy has a ZZ4 in his Vette, its a weekend toy, never sees the track...he said its "OK".
68 Camaro~LSx ~all motor
post #4 of 8 (permalink) Old May 2nd, 15, 03:02 PM
Larry
larryh56's Avatar
I've had my eye on this one a while from Year One for an 80 Truck I have: https://www.yearone.com/Product/1967-81-camaro/at350pc1
I would definitely go hydraulic roller and this has the specs you are looking for. There is one about $500 cheaper that uses Dart Iron Vortec heads that looks good too. Vortec heads are hard to beat on a basic stock build.
Welcome to TC!
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #5 of 8 (permalink) Old May 2nd, 15, 03:03 PM
ds1
Dan
We build our own. The machine shop charged us $2200 for a shortblock with Mahle coated pistons, file fit ring, Scat forged I beam rods, and steel internal balance crank. It is a 383, with Pro Comp heads and intake. Ran 11.76 last night
ds1 is offline
post #6 of 8 (permalink) Old May 3rd, 15, 02:51 PM Thread Starter
DS1
What cam dod you go with on that setup and what kind of HP/TQ are you producing. Also what cfm carb are you running
maddart is offline
post #7 of 8 (permalink) Old May 3rd, 15, 06:00 PM
Smile Re: Crate recommendation
I would go with this crate engine.
http://www.jegs.com/p/Chevrolet-Perf...52506/10002/-1
They have 10 different option packages.
TJS69 is offline
post #8 of 8 (permalink) Old May 3rd, 15, 06:02 PM
Doug
Mark, The engine from Year One sounds like a good deal. The Edelbrock E-tec heads are Edelbrocks copy of vortec heads. The price will be hard to beat from the others I have seen. $3500 is a good price for a name brand Aluminum head engine. Now you know this sounds like a remanufactured engine when you see Connecting rods: Powdered metal. These are the rods they used in the LQ4 and LQ9 truck motors. Another hint would be using stamped steel rockers. Who would buy Edelbrock heads and use stamped steel rockers.
Cdminter55 is offline
