How can you tell if your radiator is 2 or 3 core? - Team Camaro Tech
post #1 of 8 (permalink) Old May 3rd, 15, 09:43 AM Thread Starter
I'm going in with a big block, but I remember upgrading my radiator years ago, and just can't remember what I upgraded to.
Is there an easy way to identify by looking at the radiator if it is a 2 or a 3 core?
martinezr is offline
post #2 of 8 (permalink) Old May 3rd, 15, 09:48 AM
69-Pace's Avatar
Re: How can you tell if your radiator is 2 or 3 core?
The number of cores is the thickness of the actual core surface. An easy way to tell is if you look in the pass side tank through the cap opening and see one row of openings, you have a single core radiator, see two rows, you have a two core, three = triple core.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 8 (permalink) Old May 3rd, 15, 11:51 AM Thread Starter
I'm running out the garage right now to check!
Just got back. I have a 3 core. I guess I did upgrade to the big one back when I was younger, and I had an inline 6 back then too. Probably overkill. Now that it will be a 396, it should be right-sized.
Thanks.
post #4 of 8 (permalink) Old May 3rd, 15, 12:18 PM
Keith
Depends...is it a 23" or 21" cores?
I am running a Big block (AC) radiator in my '67 (probably overkill for my 406 small block), but that is a 23", 4 core...no overheating problems here...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #5 of 8 (permalink) Old May 3rd, 15, 12:55 PM
Smile Re: How can you tell if your radiator is 2 or 3 core?
Measure between the two side tanks, to get your core width.
If you have a 21" 3 core, I would try it, but be prepared to change it. Also, I don't know if a big block shroud will fit on a smaller radiator.
TJS69 is offline
post #6 of 8 (permalink) Old May 3rd, 15, 01:29 PM
Doug
Here is some information you might want to see. The Camaro Harrison radiator 4 core tank 3 row 23" came in the 396-325 hp, 396-350 hp with Automatic Transmission. This was the standard radiator for a big block Camaro without the Heavy Duty 4 core 4 row radiator. When I decided I wanted a big block in my 67 Camaro I went with a 454 cid. This was rebuilt with 20 cc dome pistons, stock crank, roller camshaft, heads mildly ported and gasket matched. It also has a Victor Jr intake with a 850 Holley DP. The car has an automatic transmission and 4.10:1 12 Bolt rear. The radiator that was in the car was a 3 row 23" that let my engine run hot. I ordered a brand new 4 core 4 row 23" radiator that finally kept the temperature around 190 degrees. That radiator lasted about 6-7 years and when I pulled it out for the last time the bottom started falling apart. I bought the Be Cool Direct-Fit Module which is still in it today.
Cdminter55 is offline
post #7 of 8 (permalink) Old May 3rd, 15, 05:07 PM
I ran a factory bbc 3 row , 23" for years on my sbc. When it was time to clean , there was more work than I had value for it.
I went with a Enthropy 2 row flat tube 23'. I have not regretted it . Runs about 100 above ambient temp. I run a factory 7 blade fan and clutch with factory shroud.
TC # 349
zdld17 is offline
post #8 of 8 (permalink) Old May 3rd, 15, 05:53 PM
Keith
Not sure of the big block shroud on the smaller radiator, but I can tell you that the reverse is true...
The small block AC cars were run with the 3 row, 23" core...the shroud for a small block with AC will also fit the 4 core 23" radiator--it is what I am running in my '67...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
