Startup Woes... - Team Camaro Tech
post #1 of 15 (permalink) Old Apr 13th, 04, 06:09 AM Thread Starter
Unhappy
Not sure if my starter is on the way out...or some other electrical issue...
Prior to last Fall, the car started right up.....
After a few months in storage, I tried starting the car....no cranking/clicking whatsoever...
The battery is new from last season...
Dash/dome/headlights are all fine when I key to the start position...
I took some 80 grit sandpaper on the terminals/connections...they were all clean to begin with...
Maybe the ign. switch?
I do need to check the fuses........
I have the starter a few hits with a hammer....nuthin...
Any way I can rule out the starter as my problem....maybe grounding the solenoid to crank it manually? Not sure how exactly to do this...
Wiring harness is in bad shape to begin with...so who knows...
Any feedback/sugggestions welcomed
1968 Chevrolet Camaro Sport Coupe (96 LT1/T56)
2002 Chevrolet Camaro SS
FraudulentRS is offline
post #2 of 15 (permalink) Old Apr 13th, 04, 06:46 AM
Denis
Even if the battery was new last Fall, that's the first thing I'd suspect.
deejaygee is offline
post #3 of 15 (permalink) Old Apr 13th, 04, 07:40 AM Thread Starter
I'll try jumping it later...
ty [img]graemlins/beers.gif[/img]
Anybody else on how to manually 'jump' the starter?
post #4 of 15 (permalink) Old Apr 13th, 04, 11:05 AM
Matt Jones
Do the lights dim when you try to start it? If they don't, then it's not the battery, since the starter isn't attemping to start the motor. If the lights do dim, then the battery is probably low, or the starting is having an internal problem.
Matt Jones
Lead Mechanical Engineer
Art Morrison Ent. Inc.
Silver69Camaro is offline
post #5 of 15 (permalink) Old Apr 13th, 04, 12:48 PM Thread Starter
The lights did dim verrry slightly...that's what was kinda confusing....Even with the headlights on....not much dimming..
I just tried jumping it...the starter did kick in and turned the motor...just not enuff to catch. Progress...
I'll buy a trickle charger later. I think that should do it...
Thanks again for the feedback
post #6 of 15 (permalink) Old Apr 14th, 04, 07:18 AM
Just out of curiousity did you remove the ground cable when you parked it for the winter? If not, do you have a clock or anything else that could drain the battery?
deerhunter is offline
post #7 of 15 (permalink) Old Apr 14th, 04, 07:44 AM Thread Starter
I left the ground on, partly out of laziness, and partly because I did start it a few times early in the winter season...
But no clock, or anything else that may have drained it...
Also curious is....the headlamps didnt dim when I turned the key to the Start position.....
Normally, a drained battery would really dim the lights, right?
I just picked up a charger....I'll put it up once I get home....hopefully that will do it
post #8 of 15 (permalink) Old Apr 14th, 04, 01:59 PM
If the battery was weak enough to not even pull the solenoid in, then no - it won't necessarily dim the lights a great deal.
dnult is offline
post #9 of 15 (permalink) Old Apr 14th, 04, 04:28 PM
Matt Jones
I think it would dim the lights quite a bit. If the battery is that weak, then the solenoid is going to draw alot of the battery's current capacity, and there wouldn't be enough left to keep the lights bright (and they wouldn't be bright in the first place).
Matt Jones
post #10 of 15 (permalink) Old Apr 15th, 04, 01:02 AM Thread Starter
I have seen both of these situations take place...the former one seems to be my current pain in the ***... (but who knows with this car)
I plan on redoing the wiring harness..
After hooking up my new charger, I tried a 50amp jump...solenoid engaged, engine cranked, then the batt gave out
I let it charge overnight....hopefully today will bring better news
post #11 of 15 (permalink) Old Apr 15th, 04, 03:28 AM
Good luck with it! Do you have a multimeter?
Poor college kid's 1968 Camaro. 327 +.060, RPM Air Gap intake, 230* @.050 I&E, 1850/4160 Holley, (waiting to install my) 180CC/64CC toplines, headers, stock TH-350 with stock converter, not sure of rear gears.
68SoBe is offline
post #12 of 15 (permalink) Old Apr 15th, 04, 06:24 AM Thread Starter
just a test light.... [img]graemlins/sad.gif[/img]
I should invest......any recommendations?
post #13 of 15 (permalink) Old Apr 15th, 04, 07:14 AM
Matt Jones
Fluke has some nice ones, and I like my Craftsman model. Always works well.
Matt Jones
post #14 of 15 (permalink) Old Apr 15th, 04, 07:40 AM Thread Starter
Thanks....yeah, I like Craftsman stuff
[img]graemlins/thumbsup.gif[/img]
post #15 of 15 (permalink) Old Apr 15th, 04, 12:00 PM Thread Starter
it is alivvvvve.... [img]graemlins/hurray.gif[/img]
Battery must have been really drained.
I let the thing charge up last night.....started right up today
Thanks for all the input...on to the next task....
