Melonized dist. gear? - Team Camaro Tech
post #1 of 4 (permalink) Old May 5th, 15, 10:28 PM Thread Starter
Does the MSD #8360 distributor come with a melonized gear already installed?
I've had no problems yet if it didn't. No metal in the oil and no oil usage.
Known to run with scissors....
__________
1969 Camaro Z/28 "clone", GMPP ZZ383, Autogear M22W, Moser 12bolt w/TruTrac 3:73.
Fred Mertz is offline
post #2 of 4 (permalink) Old May 6th, 15, 03:46 PM
Re: Melonized dist. gear?
Mine did. I later switched to a billet roller cam from UD Harold and put a GM gear on the 8360, just for safety. The cam had a Everwear press-on gear so maybe it was not necessary.
TC # 349
zdld17 is offline
post #3 of 4 (permalink) Old May 6th, 15, 05:17 PM
Larry
larryh56's Avatar
Mine came with a regular iron gear and I believe that is the usual configuration. If you have a billet cam you should probably make sure unless your cam manufacturer says it is OK.
68 RS Coupe 355/350 TH, Detroit Speed, Hotchkis, Vintage Air, 8.5" 3.42 posi 10-bolt, MagnaFlow 2 1/2" exhaust, etc.
"The public cannot be too curious concerning the characters of public men."
Samuel Adams
larryh56 is offline
post #4 of 4 (permalink) Old May 6th, 15, 09:41 PM Thread Starter
I've got 9500 miles on the motor now with no issues so I guess I'm ok.
__________
