Stripped threads in intake...need help!!! - Team Camaro Tech
post #1 of 8 (permalink) Old Oct 16th, 03, 03:03 PM Thread Starter
Red face
My son has a '67 Chevy truck he has restored. When the engine was over hauled, the alternator bracket hole in the intake near the thermostat was stripped out. This is a 327 small block with the aluminum GM intake. Is there anyway we can repair the threads or fix this problem. Thanks!!
[img]graemlins/beers.gif[/img]
supv26 is offline
post #2 of 8 (permalink) Old Oct 16th, 03, 03:31 PM
You can install a heli-coil. Easy repair and stronger than origonal.You can pick up a heli-coil kit at most any parts house.
69 Big Block / Hugger Orange Sold
65 Chevelle SS
Black 2010 Electra Glide Classic
Branded is offline
post #3 of 8 (permalink) Old Oct 16th, 03, 04:22 PM
Ditto on the heli-coil.
Check out this link for an idea of how they work.
Randy S is offline
post #4 of 8 (permalink) Old Oct 20th, 03, 02:11 PM
Check out something called a "Time Sert" You will like them much better than a Heli coil.
GMJim is offline
post #5 of 8 (permalink) Old Oct 20th, 03, 04:34 PM
I'm not sure what a time sert is but there is a keensert. A keensert is more heavy duty and requires a larger hole to be drilled. A heli coil takes up less space.
gomez is offline
post #6 of 8 (permalink) Old Oct 20th, 03, 05:04 PM
All good suggestions. Basically supv26 the helicoil is a spring-like insert. The other options are a threaded insert with keepers to prevent the insert from pulling out. Personally I'd go with a helicoil first and then upgrade if needed since the other methods require a larger hole. The old measure twice and cut once approach so to speak.
-dnult
dnult is offline
post #7 of 8 (permalink) Old Oct 20th, 03, 05:06 PM Thread Starter
Angry
Thanks for the info guys!! I'll see what we can do with it.
supv26 is offline
post #8 of 8 (permalink) Old Oct 21st, 03, 09:03 AM
The reason I like time serts over heli coils is because heli coils are NOT designed to be installed where the fastener is going to be removed from time to time. The heli coils are perfect for a fastener that is to be installed and not removed (well maybe once) A time sert is designed to be used over and over like the original threads. I have used them in all kinds of places and have never had a problem. I have even used them in blocks where the head bolts go, and spark plug thread repair. [img]graemlins/thumbsup.gif[/img]
http://www.timesert.com/
GMJim is offline
