camshaft ID - Team Camaro Tech
post #1 of 4 (permalink) Old Oct 9th, 03, 02:04 AM Thread Starter
In Memoriam
I have a camshaft that I don't know anything about. It was in an engine that I bought and when I decided to go through the engine, I found one lobe bad. It ran and sounded great, but I didn't want to put it back in with that bad lobe. It doesn't have much info on the cam. If I knew what it was, I would like to buy another one like it. I would greatly appreciate any help from you "numbers" guys. The only thing I see on the cam is as follows:
CWC
RSCO 55
Daytona Yellow 69 Z/28
69 coupe, 454 and 400 turbo
67 convertible project (the money pit has been opened)
trentonZ28 is offline
post #2 of 4 (permalink) Old Oct 9th, 03, 02:18 AM
Is there any stampings or engravings on the very back of the cam, on the flat portion at the rear, facing the firewall?
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #3 of 4 (permalink) Old Oct 9th, 03, 08:52 AM Thread Starter
In Memoriam
No,none on either end. The info posted was on the body of the cam. I found where CWC, was connected with Tektronic. They made cams for the big Three, as well as others, but I can't find anything else about them or the cam.
post #4 of 4 (permalink) Old Oct 10th, 03, 05:44 PM
Smile
Sounds like you have a knock-off of the great stock, -929 cam to me with out more info...
pdq67
