Blind Head Bolt Holes w/Pin Hole? - Team Camaro Tech
post #1 of 4 (permalink) Old May 16th, 15, 09:25 PM Thread Starter
Chad
cv2065's Avatar
Getting my Etech 170 heads put on and had a question. The bulk of the head bolt holes go into the water jacket, and I'll be using Permatex 80632 for those bolts. There are a few holes across the top that appear blind, but they all have a pin hole in each one. I'm assuming that those holes go through to the water jacket as well, but not sure why they are there? ARP says that if the hole is blind and does not go into the water jacket, to use the ARP lube and torque accordingly, but if its not blind and goes into the water jacket, to use the Permatex. Would I treat these 'blind holes' with pin holes with the ARP lube or the Permatex?
Thanks.
67 Black RS Coupe, 383, M21 & 10 Bolt Posi. Edelbrock E-Tech 170 Heads, 2204 Roller Cam, Air Gap Intake.
cv2065 is offline
post #2 of 4 (permalink) Old May 17th, 15, 03:41 AM
Re: Blind Head Bolt Holes w/Pin Hole?
If in doubt, use thread sealant on all the bolts not only to prevent any leaks, but also to keep bolt torque the same setting on the torque wrench.
68 Camaro~LSx ~all motor
post #3 of 4 (permalink) Old May 17th, 15, 05:51 AM
X2 My late model (ZZ4) block is the same, with the small holes in the top row. They do go into the water jacket. Used sealant on all.
BPOS is offline
post #4 of 4 (permalink) Old May 17th, 15, 05:53 AM Thread Starter
Chad
cv2065's Avatar
Thanks guys!
cv2065 is offline
