VERY weird problem - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 19th, 03, 10:59 PM Thread Starter
robert
rolling-robert's Avatar
im almost finished building this 355ci engine (see sig)
but the distributor wont reach the oilpump!
the difference is like 2 inch or so!
i noticed that there is some sort of passage above the oilpump-shaft.
weird isnt it?
from above i can see the shaft from the oilpump.
plz help me! i wanted to test the oilpressure today.
V0423CLL
171222757
Z28 1984
'77 355ci/COMP cam 218/224 .464/.470 114 LSA
rollerrockers1.5/9.72 forged pistons
ported '66 461 heads 1.94,1.5/Flowtech shorty headers
edelbrock 600/performer rpm intake
th350/shiftkit/hughes2500stall
4th gen 3.23 10 bolt POSI.
rolling-robert is offline
post #2 of 8 (permalink) Old Sep 19th, 03, 11:49 PM
You did put the oil pump shaft that goes between the distributor and oil pump in, right?
"This is not a cheerocracy...I make the cheercisions around here"
travis is offline
post #3 of 8 (permalink) Old Sep 20th, 03, 02:30 AM
Eric
I bet the oil pump drive shaft is missing. If you need to put one in you have to drop the oil pan and oil pump, put it on the oil pump, and put it all back in place.
Eric68 is offline
post #4 of 8 (permalink) Old Sep 20th, 03, 02:39 AM
And, if that is the case, and you have to drop the pan, don't forget to put the little pump shaft sleeve on!!!
travis is offline
post #5 of 8 (permalink) Old Sep 20th, 03, 06:48 AM Thread Starter
robert
man, shame on me!!
yes i didnt put that darn shaft in between ,
there is no way i can install that shaft from above, do i??
i bet that sleeve wont fit from above...
using it without the sleeve is a stupid idea, isnt it?
[img]graemlins/clonk.gif[/img] [img]graemlins/clonk.gif[/img] [img]graemlins/clonk.gif[/img]
post #6 of 8 (permalink) Old Sep 20th, 03, 07:24 AM
Eric
Originally posted by rolling-robert:
man, shame on me!!
No, there isn't. you HAVE to pull the pan and install the shaft and sleeve from the bottom. Aftermarket hardened shafts often have a steel sleeve that is pinned on instead of the factory plastic one.
No it won't fit from above. I know this because I've made this mistake myself [img]graemlins/clonk.gif[/img]
Yes. For the sake of everything Chevy, don't try to run it without the sleeve [img]graemlins/clonk.gif[/img]
Not trying to rub it in - just drop the pan, put the shaft in from the bottom, and you'll be fine. Its a little work but can be done in a day (a long day).
Good luck.
Eric68 is offline
post #7 of 8 (permalink) Old Sep 20th, 03, 12:08 PM
a67
You can use the stock shaft and the plastic sleeve. Or, purchase an aftermarket shaft with an integral steel sleeve. The steel sleeved shaft is more durable.
If you use the plastic sleeve heat it in water before fitting it to the shaft/oil pump (boiling is OK). I've cracked all too many fitting them cold. The plastic sleeve has a raised ring on the inside so that it doesn't fall off during assembly.
Bob.
[ 09-21-2003, 07:00 AM: Message edited by: a67 ]
a67 is offline
post #8 of 8 (permalink) Old Sep 20th, 03, 05:12 PM
Red face
I gotta admit I did it on my 496........
But I didn't have all my pan bolts in yet when I saw the box it was in!!!!!!!!!!!!!!!!!!!!!!
pdq67
