Carb Question - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 25th, 04, 11:39 AM Thread Starter
Del
When I pulled the bowl of my holley 750dp the vent baffle (piece of plastic) was in the bowl. Can someone tell me where on the metering block this vent gets installed, I matched the holes up from the plastic vent with the studs that is at the 12 o'clock positon on the metering block, my carb book shows the part but doesnt show or say where it goes.
I wish I knew how to add a pic to this post, so I can show you.
Thanks,
penquin is offline
post #2 of 3 (permalink) Old Apr 25th, 04, 05:00 PM
USN1969SS's Avatar
Penquin, if it is the baffle I'm thinking of, a small piece, maybe an inch long with a diaginal (sp?) opening and a hole on either end, one side flat and the other side protrudes, it covers the regtangular opening on the top center of the plate. It has been a while but I think there are little studs it sits on. If not, ???
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
USN1969SS is offline
post #3 of 3 (permalink) Old Apr 27th, 04, 04:32 AM Thread Starter
Del
Thanks 69SS,
Thats where I was thinking it went, I just wanted to verify before I assemble everything together and install it.
penquin is offline
