late model lt-1 in 68 - Team Camaro Tech
post #1 of 3 (permalink) Old Apr 7th, 02, 04:16 PM Thread Starter
I've searched the archives and found that the A/C compresssor from a camaro or firebird will interfere with the subframe. Is there a fix other than using an A/C delete pulley? Is the interference in a location that will allow the frame to be notched easily? Is the accesory drive setup from an impala different? Thanx.
rick
rick is offline
post #2 of 3 (permalink) Old Apr 7th, 02, 04:40 PM
Tim
http://www.geocities.com/MotorCity/S...5/camaro1.html
(Quote from this link hope it helps)
Due to compressor/frame interference problems I originally used a 1LE A/C delete pulley to run the motor. Since I live in Las Vegas and A/C would be a plus, I recently swapped over to the Corvette accessory drive which locates the A/C compressor on the drivers side of the motor high enough to clear everything. I considered the Street and Performance manufactured pulley set-up but it was a little bit too pricey.
Trick1 is offline
post #3 of 3 (permalink) Old Apr 8th, 02, 05:24 AM Thread Starter
Sorry that I wasn't clear. I want to maintain the A/C compressor on the passenger side. I am aware that the corvette setup is different.
Also thanx for the link. I'd seen it before, but couldn't find it in my recent searches.
rick
rick is offline
