69 motor frame bracket in 67 - Team Camaro Tech
post #1 of 3 (permalink) Old Oct 14th, 03, 04:55 PM Thread Starter
In my classic ind. catalog it has a lower set of frame brackets to mount the motor mounts, can I use these on a 67 also, allowing the engine to sit lower Without firewall interference?
sherr20 is offline
post #2 of 3 (permalink) Old Oct 14th, 03, 06:25 PM
Smile
Your interferance probably isn't at the firewall, but probably with header clearance at your power steering box. If you look, the 69's low power engines used a shorter mount also. This can also lead to balancer clearance issues if you use larger than a 6" balancer.
TJS69 is offline
post #3 of 3 (permalink) Old Oct 15th, 03, 03:06 PM Thread Starter
So I should keep my tall ones huh?
sherr20 is offline
