BB Performer RPM under flat hood? - Team Camaro Tech
post #1 of 17 (permalink) Old Apr 14th, 04, 08:13 AM Thread Starter
OK Here's my dilema... I'm nearing completion of my 454 engine buildup. I've already purchased and installed an Edelbrock Performer RPM manifold and Edelbrock 750 carb. I've also purchased the proper engine frame mounts.
Will I fit this beast under the stock flat hood on my 67? Edelbrock's site says NO!
rasp67 is offline
post #2 of 17 (permalink) Old Apr 14th, 04, 08:29 AM
I have a 67rs I just put a 454 in with the same intake as you and a Holley 750. With a 14 inch air cleaner and a cowl hood the hood will not close. With a smaller air cleaner it should work no problem, dont know if this helps you or not. I can close the hood without the air cleaner on and I have about 1/4 inch between the top of the air cleaner stud and the top of the cowl.
Calebs67rs is offline
post #3 of 17 (permalink) Old Apr 14th, 04, 05:04 PM
I have the grated SS hood on my 68, which I believe allows a bit more room than the stock flat hood. I'm sorry to say I bet you don't get that intake under that hood with an air cleaner. I hope I'm wrong. I have just made an intake change, from a Torquer2 to a GM cast iron Holley 4 barrel intake. I mean it takes it all, with a drop base air cleaner. Goo luck.
HG
hgerrick is offline
post #4 of 17 (permalink) Old Apr 15th, 04, 05:56 AM Thread Starter
Unhappy
Oh well, I guess this manifold is going back. On the big block I measured from the motor mount long bolts to the top of the carb and came up with 19.75 inches. And then did the same on the small block, which is in the car. It measured just under 20.00 inches to the underside of the hood. Too close to tweak anything.
I have to consider a lower intake, bummer!
Thanks for the replyís.
rasp67 is offline
post #5 of 17 (permalink) Old Apr 15th, 04, 07:51 AM
Josh
I went through the same thing as you. The combo will not fit. I ended up getting a cowl hood and I still need the drop base air cleaner. I built my 454 from scratch and I could not stand the thought of putting a cork(restrictive intake manifold)on top of all the hard work and money I spent on the motor. Looks killer too!
J early is offline
post #6 of 17 (permalink) Old Apr 15th, 04, 08:54 PM
hey calebs,i have solved clearance issues like yours in the past by using a castle style bolt(i think thats whai it's called)instead of a stud.
the bolt has a round top and a square shoulder under the head,it screws in flush with the air cleaner top and looks pretty smooth too!just find the right thread and cut to length.screws in with thumb pressure and i've had no problems removing mine.it will save you 3/8 to 1/2"compared to a wing nut.
Eric
86 camaro,383,topline vortecs,scat crank,wiseco forged 9.5:1,6"scat rods,comp xs282s,performer rpm,750 proform vac sec,msd in cap, hooker coated 1 5/8"headers,3"flowmaster,700r4,2800 stall,3.42 10 bolt posi,hotchkiss lca's,aje tube k member & a-arms
SLEEPER 86 is offline
post #7 of 17 (permalink) Old Apr 16th, 04, 05:54 AM
Thanks, I will try that.
post #8 of 17 (permalink) Old Apr 16th, 04, 11:07 AM
How about a BB with a Holley Strip Dom. single plane under an SS hood??
pdq67
post #9 of 17 (permalink) Old Apr 18th, 04, 04:51 AM
Johnny
I currently have a Eldebrock C-396 intake & a 750 CFM Eldebrock carb on my 396 & a drop base 14" Factory air filter, my air filter top rubs the hood pad, I'm getting ready to change to a Holley 750 Double Pumper Carb, What would be a good intake to use? I have oval port heads, a comp cams extreme enegry cam, a SS hood.
johnnyr is offline
post #10 of 17 (permalink) Old Apr 18th, 04, 04:31 PM
red
Thumbs up
got 67 camaro with 427 and factory mounts. Have edelbrock intake c-66 . Dual quad with the carbs in set up,that edelbrock recomended. Fits under hood and looks great. It runs great and looks great. The complete set up is outlined from edelbrock. I was a holley man all my life till now.
Charlie
red67L78 is offline
post #11 of 17 (permalink) Old Apr 19th, 04, 02:02 AM
Johnny
Hey Red67L78 can you post a pic of that setup?
johnnyr is offline
post #12 of 17 (permalink) Old Apr 21st, 04, 04:21 PM
Johnny
Has anyone tried a Weiand Stealth intake? I measured my old Holley Cast Iron Intake today & the front of the carb pad is 4 & 1/8" & the rear of the carb pad is 5 & 5/8ths high. The Stealth measures 4.75 front & 5.75 rear. this is suppost to be a real good intake if it will fit with no promblems. If not could one be machined down to the stock specs?
johnnyr is offline
post #13 of 17 (permalink) Old Apr 22nd, 04, 03:54 AM
Josh
I have use a stelth in my set up. It is lower than some intakes but I still needed a cowl hood and drop base with 3" filter.
J Early
J early is offline
post #14 of 17 (permalink) Old Apr 22nd, 04, 04:22 PM
Johnny
What drop base air filter housing are you using?
johnnyr is offline
post #15 of 17 (permalink) Old Apr 23rd, 04, 09:26 AM Thread Starter
Okay, now I really confused! I just found out two things:
1) I canít exchange my Performer RPM manifold for the std Performer without a 20% charge (Summit).
2) As I mentioned Iíve read on Edelbrocks site that the RPM wonít fit under the stock hood. However, the measurements posted are only different by .6 inches.
From what Iíve measured it appears neither will fit. When referring to Big Block Camaros, did they come stock with a cowl hood? What Big Block hood/manifold combos work?
rasp67 is offline
