Bronze distributer gear problem - Team Camaro Tech
post #1 of 8 (permalink) Old May 25th, 15, 11:42 AM Thread Starter
Dale
I am running a solid roller cam in my 67, while driving yesterday the motor lost ignition and died. Found the bronze gear destroyed. Can I replace with a new composite gear change the oil and run it or should I pull the motor and clean out the bronze shavings. I've lost cam lobes in the past on other motors and pulled the motor out but not sure how much damage the bronze wil do. Any opinions
67 RS Camaro
71 SS Nova
68 Chevelle
67Dale is offline
post #2 of 8 (permalink) Old May 25th, 15, 02:09 PM
Morgan
Re: Bronze distributer gear problem
It has been eating itself up and hopefully is in the filter. I would drain the oil, change the filter and run a thin oil, 10/30 or less, get it up to temp and drain and refill with a new filter and the oil you use. My buddy went through 3 before going to the composite, no issue. You can also buy the gm melonized distributor gear for $40 instead of the $100 composite
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
1971ls6 is offline
post #3 of 8 (permalink) Old May 25th, 15, 03:49 PM Thread Starter
Dale
Thanks Morgan, I'll try a couple oil changes like you suggested. I was thinking the same thing as you. I already ordered a gear but will have to remember the melionized one if I need one some other time.
67 RS Camaro
71 SS Nova
68 Chevelle
67Dale is offline
post #4 of 8 (permalink) Old May 25th, 15, 07:33 PM
I agree with Morgan, and if it were me I'd also cut open the filter to "see" exactly how much material from the gear was caught in the filter. It will take all the wondering out of the equation.
NH69Z28RS is offline
post #5 of 8 (permalink) Old May 25th, 15, 11:09 PM Thread Starter
Dale
Good idea Scott, I'll do that. I think ill do several oil changes to try to flush as much as I can out of the motor.
67 RS Camaro
71 SS Nova
68 Chevelle
67Dale is offline
post #6 of 8 (permalink) Old May 26th, 15, 05:21 AM
If you cut apart the filter after each flush you should be able to monitor the material in the filters becoming less and less. That will prevent you from not flushing enough and from flushing more than is necessary. Good luck and please update your thread with the results, I'll be waiting and watching to see how it goes for you?
post #7 of 8 (permalink) Old May 26th, 15, 07:29 AM Thread Starter
Dale
Thanks guys, I'll post a update when I get it cleaned out and running again. Going to try to get to it this weekend.
67 RS Camaro
71 SS Nova
68 Chevelle
67Dale is offline
post #8 of 8 (permalink) Old May 26th, 15, 07:58 AM
The poly gear is OK with a std vol oil pump - can be a bit iffy with a HV pump
BPOS is offline
