Larry
Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools | Display Modes |
327 runs strong but won't idle??? 1968 Camaro
Hello,
I have a rebuilt flattop 327 with a new holley 600 and elderbrock aluminum heads. The car ran perfect until the other day when it stalled at a light. It was difficult but I did get it started and it drove strong on the way home. I checked all of the vacuum lines, fuel lines, and bolts to be sure there were no leaks. I looked down into the new carb and could see the jets spray gas when I moved the linkage. I checked the plugs and wires and all are fine. I did see a small amount of oil residue in the air cleaner that was never there before. The car will right start up when it is cold but seems to build up quickly and stall even in park or neutral. I recently had the power glide swapped for a new TH350 and even checked the vacuum lines from the transmission. The engine does not make any tapping or strange noises. Can anyone point me to a possible cause.
Sponsored Links | |||
alex
Re: 327 runs strong but won't idle??? 1968 Camaro
When you say build up quickly do you mean load up rich at idle.I f that's the case you might have a spec of dirt in the needle valve or your float could be porous or out of adjustment . I would look at the first one . To clear start the car and with a small and I mean small rhythmically tap the fuel bowl while revving the engine up and down. This will usually clear the needle and seat unless you have a boulder in there LOL .If that works change the gas filter .Alex
Originally Posted by ss27
View Post
Is your choke butterfly opening up all the way as the engine warms up?
If not, that would cause it to run excessively rich.
check your fuel levels. To high of a fuel level will cause this (just happened to me!). Ethanol residue can gum up the carb. Suggest opening it up and cleaning it.
Kevin
The new holley is a vacuum secondary with electric choke. It has less than 300 miles on it but I suppose it could have sucked up some gunk. I will remove the carb, clean it thoroughly and re-install. Thanks for your help. Larry
its the ethanol film. I rebuilt my qjet less than 50 miles ago. Took it for a ride on Friday and float was glued to the bowl and a piece of film in the jet. The gas evaporates and creates the film.
Kevin
Maybe a pin hole in the float.
1969 Z28
1969 Firebird 400
My new project for 2010 DONE/ Sold.
2002 Camaro SS LE/SLP
67 Nova SS 327, M20, 3.73
Joe
Good idea to double check your float level as others have suggested.
Next you need to re-adjust your idle mixture screws. They could be set too rich. As a base-line run them in (clockwise=leaner) until they bottom out (do not use very much force), then turn them back out (counterclockwise=richer) approx. 1.5 turns. Use a vacuum gauge to tune your idle mixture for the leanest setting that will pull the highest vacuum at idle. while idling with the vac gauge connected, turn each idle mixture screw out 1/4 to 1/2 turn at a time and let the idle stabilize again. Continue to richen the idle mixture slowly until you find max vacuum reading. Going too rich will cause the idle quality to degrade so then turn back lean to find that sweet spot.
600cfm may be a bit too much for a 327. You may try dropping down a jet size or two on the primary side.
The important thing here is that you ask me what kind of car I've got. "I've got a BITCHIN' CAMARO"
'68 350 4 speed
Distributor lockdown bolt tight so that disti can't retard?
Other than that, fuel bowl level would be my guess.
My holly 650 would just flood itself when I got my car back from restoration, it would be fine when driving but would stall whenever you let up on the gas.
Holly's are supposed to be prone to needle/seat problems so I removed and cleaned both needles/seats and it hasn't happened since.
Be careful to note how many threads are showing on your needle before removing it because it sets your float level.
Once you remove the top retaining screw, the small nut/cap that goes over the top of the needle just pops up, don't turn it or you will change your float level.
Steps
Also VERY COMMON after a rebuild and NOT done
When a carb, even out of the box is put on, the float levels NEED to be set. The accelerator pump gap checked and re set... NEEDS mixture and idle speed screw set to factory 1 1/2 turns and the secondary butterflies correctly set while running... with the idle timing in ball park.
All of the above are the basics of basics must do stuff... and the most common of faults will not idle right , has a bog, etc
Everything Steps says is correct. My bet is on the fuel being high whether by adjustment or by crud in the needle and seat. do you smell it going rich and see dark smoke when it stalls?
68 302 M20 - 85 IROC Z
Spray out the idle air bleeds, preferably with air, or brake cleaner before doing anything, as it is the easiest. New carbs often have casting flash and chips inside, demons were the worst.
69 Copo 9560 ZL-1 automatic [email protected], 1.95 on f70-14 polyglas F.AS.T. Race June 2016
69 Copo 9560 ZL-1 4spd [email protected] 1.93 60ft on F70/14
PSMCDR 2014
71LS6 vette [email protected] PSMCDR 2012 SOLD
George
How is the tank? Is it full of crud or rust? Fine rust will get through any fuel filter and eventually muck up your carb. Ask me how I know.
Sponsored Links | |
Previous Thread
Next Thread
Thread Tools | |
Display Modes | |
Posting Rules | |
