Oil leak - Team Camaro Tech
post #1 of 4 (permalink) Old May 26th, 15, 07:28 PM Thread Starter
Doc
Question Oil leak
Has anyone found a sealant or 2 part epoxy to use where the oil pan and timing cover meet on a small block chevy?
Thanks in advance.
Danzo is offline
post #2 of 4 (permalink) Old May 26th, 15, 07:43 PM
Bobby
Re: Oil leak
I use RV sealer. Never had any problems.
1976 Camaro, M20 Muncie 4 Speed, Hurst equipped
1972 Camaro, Full Drag Car
rdobbs1977 is offline
post #3 of 4 (permalink) Old May 26th, 15, 09:29 PM
Doug
Re: Oil leak
This is what I have use on the rear main seal and on the timing chain cover and oil pan. Permatex Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker. I also use it on the front and back of the intake manifold. http://www.permatex.com/products-2/p...sealant-detail
Cdminter55 is offline
post #4 of 4 (permalink) Old May 27th, 15, 04:46 AM
Re: Oil leak
In order for RTV to seal, both surfaces should be cleaned with BraKleen® or lacquer thinner.
Got to have a dry surface for adhesion.
