383 oil pan size - Team Camaro Tech
post #1 of 6 (permalink) Old May 27th, 15, 06:49 PM Thread Starter
383 oil pan size
My engine builder said he wants me to run a high volume oil pump, will a 5qt cheater pan with windage tray and baffles work? Or will I need bigger compasity pan
He suggested a 6 or 7 qt pan, but it will hang too far down for my liking
Any suggestion ???
Car is street driven but will see the track a few tims a year
383
10.7:1
6" rods
Afr 210 heads
Retro fit hydraulic roller cam
Crane short travel roller lifters
Roller rockers
500 to 530 hp range
67 SS clone,383 ,Built TH700r4,2500 stall converter,3.73 gears,eaton possi,1" lowering kit,1"sway bars ....more upgrades on the way
11sec67 is offline
post #2 of 6 (permalink) Old May 27th, 15, 06:52 PM
ds1
Dan
Re: 383 oil pan size
I have used the 7 Qt kick out pans. Stock depth with extra capacity to the sides. I ran a 68, stock front suspension with a 383 in the 11s.
ds1 is offline
post #3 of 6 (permalink) Old May 27th, 15, 11:11 PM
Darin
ilikeike's Avatar
I'm most likely going to order a Canton road race pan for my stroker build with a 7.5" sump 5qt. I was looking at the milodon stroker pan,but it has a 8.25" sump 6qt cap. I want all the clerance I can get,since I'll be low. Both pans are good for upto 4" stroke.
1968 Butternut Coupe,
421" Dart SHP block
TKO 600 RR
Dutchman 9" w/3.70 US Gear Lightning r&p
Global West arms
Budnik wheels
ilikeike is offline
post #4 of 6 (permalink) Old May 28th, 15, 04:22 AM
Moroso 20190
post #5 of 6 (permalink) Old May 28th, 15, 04:36 AM
kevin
not all headers will work with a kick out pan. keep that in mind
I got a 7 quart deep pan from chris straub with baffles and windage tray, along with the proper pick up tube .
the pan does not go below the sub frame on my 68 with stock suspension
flat tire is offline
post #6 of 6 (permalink) Old May 28th, 15, 06:19 AM
Doug
I had a Canton oil pan on my 454. For some reason I always was seeing small drops of oil when parked. I could wipe the pan down good with a degreaser but the little drops would come back. I finally purchased a Moroso 7 qt oil pan and the leaks stopped. I check the Canton oil pan out when I had it off and the pan had cracked along the welds. I mentioned it to some friends and they said they had heard the same thing. Just letting you know what happened to me.
Cdminter55 is offline
