Engine running cooler on one side? - Team Camaro Tech
post #1 of 6 (permalink) Old Dec 31st, 04, 02:23 PM Thread Starter
stevo camaro's Avatar
What would make an engine bank run colder than the other??
350, 9.5:1 comp., .30 over, comp cam 260-H 440 lift, can't recall duration. #442 casting heads with screw in rocker studs. Crane full roller rockers, (I had them laying around and said what the heck,) edelbrock performer with stock Q-Jet, headers with new exhaust system. No X-over pipe.
The drivers side bank, if you put your hand at the exhaust will almost burn your hand, but the pass. side blows warm to cool.
This is after the motor is warmed up & run down the hi-way a couple miles.
Engine has 120 miles on it. Both sides feel the same compression wise to the hand at exhaust tip.
Anyone know this? [img]graemlins/clonk.gif[/img]
67 RS 327, 4-speed, posi, done.
67 Modified, 454, TH-400, posi, under construction.
67 SS 396, 4-speed, basket case.
72 RS, sitting, partially done.
55 210 post, 2 door, 327 4-speed runs good.
55 2 door post, gasser project
69 Cadillac ElDorado
69 4x4 suburban
59 ElCamino
Some mornings, it's just not worth chewing thru the leather straps"
stevo camaro is offline
post #2 of 6 (permalink) Old Dec 31st, 04, 02:32 PM
Paul
Bad fuel distribution, one side is really lean...
Best of 1.55 - [email protected]
paulm is offline
post #3 of 6 (permalink) Old Dec 31st, 04, 08:20 PM
David Pozzi
davidpozzi's Avatar
Steve,
Check the carb, maybe an idle air bleed is plugged putting some raw fuel into the engine on one side.
davidpozzi is offline
post #4 of 6 (permalink) Old Jan 1st, 05, 06:18 AM
You're doing a compression test by putting your hand over the end of the exhaust pipe? Judging exhaust temperature in the same location? I think you're about 15' too far away to do any troubleshooting. What do the headers feel like right at the exhaust port? How do the plugs look from bank to bank?
"For those that will fight for it...FREEDOM ...has a flavor the protected shall never know."
Semper Fi! L/Cpl Edwin L. "Tim" Craft, B Co 3rd AT's, Khe Sanh Combat Base, February, 1968
onovakind67 is offline
post #5 of 6 (permalink) Old Jan 1st, 05, 06:21 AM
click's Avatar
Put ice cubes on the hot side Stevo [img]smile.gif[/img] smart A$$ aint I [img]smile.gif[/img] happy new year to you both.
click is offline
post #6 of 6 (permalink) Old Jan 1st, 05, 07:50 AM Thread Starter
LOL Ahhhh, no. I have a tester for that. I do not have the time, nor the space, with 2' of snow at the door entrance & 3 cars allready in the shop, to do a complete troubleshoot. It hasn't stopped raining & snowing for 8 days & there's no end in sight. Sooo, I thought I'd run this by you guy's in case there is a simple or common cause that someones allready familiar with. If there is a dead cylinder, or major issue with 1 or more cylinders in 1 bank, I for 1, can tell by putting my hand at the exhaust.
That is why I make that statement. I've not had a motor in recent memory, act like this.
Hope that makes it easier for you to understand there Nova. [img]smile.gif[/img]
69 4x4 suburban
59 ElCamino
