How much metal is normal? - Team Camaro Tech
post #1 of 6 (permalink) Old Aug 19th, 03, 04:36 PM Thread Starter
Rodney
Unhappy
How much metal would be normal in an engine with about 200 miles and run on a dyno? I tore the filter apart today and there is some in the all the pleats. I ran a magnet across it and got metal. I also have a magnetic plug, and found metal on it when I removed it. It was covered in little slivers. This engine has already had one rebuild with about this many miles. Had 3 rod bearings fubar'd and ruined the crank. I am afraid it is the same thing. Before it was knocking and didn't run good and ran hot. This time I am getting it running really good, no knocking, and running cool.
I am about to loose it. Let me know what you think. I am going to put some miles on it and then try changing the oil again and see how it looks.
69 RS Camaro (383,700r-4,12-bolt w/4.11s)
79 WS6 Trans Am (406SBC,factory 4-spd,3.23 posi)
87 GTA Pace Car Clone (350TPI,700r4)
97 Bonneville SSE 40th Anniv. (3800 V-6,All Power)
Check out my site at
wildkatz is offline
post #2 of 6 (permalink) Old Aug 19th, 03, 04:54 PM
Royce
I don't build engines as a profession but, I have built quite a few. Some metal is normal during break-in. It is hard to say without seeing exactly how much and how big. Was everything washed before you assembled it (oil passages cleaned with soap and water and rifle brushes, same for the crank)? If everything wasn't washed down it will show up, it also likes to get stuck in the bearings. Unless you had quite a bit I don't think you have anything to worry about. The oil should have been changed right after breakin, all that moly/assy lube and dirt/metal will clog up the filter in no time.
I bought a brand new truck a few years ago and when I changed the oil the first two times I had metal on the drain plug. After the second oil change I went to synthetic and never had even a flake on the plug again. Just so you know it is normal to have "some" shavings.
Royce (NO XQSSS) Bradley
camaroman7d is offline
post #3 of 6 (permalink) Old Aug 19th, 03, 10:25 PM
Sean
i agree with camaroman. some metal is normal right after a rebuild. the main issue is no big pieces, just some light glitter. also hopefully you cleaned everything real well before re assembly, metal likes to find its way into oil holes in the crank and whatnot during machining, and usually finds its way to your bearings as well. i wouldn't be to worried yet, just keep a close eye on it, and if you find a bunch of gold looking "glitter" thats non ferrous, thats a bad thing. thats usually the copper from the bearings, meaning a bearing is on its way out. i think you'll be o.k. from what you say (it would be easier to say if i could see it as well), just keep an eye on it, and cross your fingers. good luck with it [img]graemlins/thumbsup.gif[/img]
Sean
Franklin D. Roosevelt
68rs406 is offline
post #4 of 6 (permalink) Old Aug 20th, 03, 04:52 AM Thread Starter
Rodney
It is silver and is magnetic. I am going to drive it normal and change the oil in about 100 miles. What do you guys think about the motor flushes that WalMart and Advance has that you pour in and run the car for 5 minutes? Would that be good for it?
Thanks for the replies
wildkatz is offline
post #5 of 6 (permalink) Old Aug 20th, 03, 09:21 AM
Royce
I don't think a "motor flush" is needed (that is more for sludge buildup). Just change the oil a few times and keep an eye on the drain plug and filter. If after a few oil changes you are still finding metal in sugnificant amounts you might want to investigate. Make sure you are using good quality oil as well (there really is a difference).
post #6 of 6 (permalink) Old Aug 20th, 03, 04:35 PM Thread Starter
Rodney
Thanks for all the replies. The reason for the first rebuild was 3 rod bearings. The inside of the filter pleats was gold. I sent it back to them and they rebuild it and couldn't give me a reason. When I got it back I had it put on the dyno straight out of the crate. I have about 200-250 miles on it after the dyno and have changed the oil(std Mobil One 10w-40) several times. Seems like everytime I changed the oil, I dropped the plug into the pan and had to wipe it off before looking at it. This is the first time I have cut open the filter.
I'm going to drive it easy about 100 miles and change the oil. And do this for about 3 times and then come to a conclusion. Thanks for the help and I'll keep you updated.
wildkatz is offline
