cool headers - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 23rd, 01, 12:43 PM Thread Starter
where's everybody coming up with those cool lookin' silver/grey powder coated headers. Are they custom. what do they run if i were to have my Hokkers done? Does it last for more than 6 months?
69cp.fs is offline
post #2 of 6 (permalink) Old Feb 23rd, 01, 01:51 PM
Gene
The headers you see are ceramic coated. The coating will last for years if the headers are prepped properly before the coating is applied. Also, headers are usually coated inside and out.
The coating actually does provide some benefits besides looking good. The ceramic coating inside the header reflects heat back into the exhaust gas as it is passing through the header. Hotter exhaust travels faster than cool exhaust. Also, by keeping the heat in the exhaust, the headers radiate less heat into the engine compartment.
Ceramic coating is pretty expensive. If you already have a set, you can have a shop do them. One of the more well known places is Jet Hot. Ceramic coating is pretty expensive and runs about $300 for a set of headers.
Pearl blue & white 69 Camaro with supercharged 350, Tremec TKO, and 3.73 12-bolt
See my website updated 12/17/00 at:
www.geocities.com/gheatly
gheatly is offline
post #3 of 6 (permalink) Old Feb 23rd, 01, 05:16 PM
Joseph
check out jegs.com. dynomax has a set of ceramic coated headers for $210.00. im thinking about getting these.
cam1967rsss is offline
post #4 of 6 (permalink) Old Feb 25th, 01, 07:55 PM
I just got mine done it was $235.CDN turned out excellent.
craggar is offline
post #5 of 6 (permalink) Old Feb 26th, 01, 03:25 AM
I have a set on my truck. they have been on there for about two years. I got mine from Jet Hot.
69 RS Z/28 96 IMAPLA SS 82 C10 SWB 300HP 350
Tim Meredith is offline
post #6 of 6 (permalink) Old Feb 26th, 01, 07:15 AM
On my old set of headers I sandblasted them down to bare metal, degreased them, and then put on a couple coats of high temp silver coating from Eastwood Co. It cost under $50 all together. Not as good as cermaic coating but a lot cheaper!
z28camaro69 is offline
