69 Z28 head gasket - Team Camaro Tech
post #1 of 12 (permalink) Old May 31st, 15, 09:41 AM Thread Starter
MIKE
miket1's Avatar
69 Z28 head gasket
I am rebuilding the 302 engine in my 69 Z28, what is the original factory head gasket thickness,, was it a steel shim gasket.
Thanks,
miket1 is offline
post #2 of 12 (permalink) Old May 31st, 15, 10:12 PM
Gary
69Z28-RS's Avatar
Re: 69 Z28 head gasket
Yes, the original was a steel shim gasket.
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #3 of 12 (permalink) Old Jun 1st, 15, 06:30 AM
Jon
.017 to .019 as I recall.
Jon N
dyno jonn is online now
post #4 of 12 (permalink) Old Jun 1st, 15, 07:43 AM
Lynn
Hey Mike:
Yes, as Jon said, the original was a steel shim type.
How far down in the hole are the pistons?
Factory pistons?
Are all 8 the same, or at lest close to the same?
Lynn
bilodeaulynn is offline
post #5 of 12 (permalink) Old Jun 2nd, 15, 01:07 PM Thread Starter
MIKE
miket1's Avatar
Pistons are down .007-.008, block was decked so all are very close to same,
bored .030 w/ 11:1 trw's , using the GM #140 offroad cam, I checked clearance w/ no head gasket installed and have good clearance, I am looking at Cometic .030 compressed which will give a quench of .037-.038, maybe I should use a thinner gasket, how tight can I go on quench
miket1 is offline
post #6 of 12 (permalink) Old Jun 2nd, 15, 02:16 PM
Lynn
You are about as tight as you want to go with the old TRW's (I am guessing the forged piston, running at least .004 clearance). Smokey Y used to say .005 to .0055. Other builders disagree. Frankly, I am afraid to run the old forged at less than .004. You get some piston rock when cold. Shouldn't be enough to cause the "slap" sound, but may get close to the head until warmed up.
The old "rule of thumb" is .010 for each inch of bore size. I have cheated a bit closer with forged TRW's at .035 on a 4 inch bore and gotten away with it each time. Can't promise though.
Again, this assumes forged slugs.
Lynn
post #7 of 12 (permalink) Old Jun 2nd, 15, 02:40 PM
Doug
Here are two sets of head gaskets that will work with the distance the pistons are down in the hole. http://www.jegs.com/i/Cometic-Gasket...ductId=2848865 and http://www.jegs.com/i/Cometic-Gasket...ductId=2848865 These are one of the best gaskets made and they are MLS gaskets.
Cdminter55 is offline
post #8 of 12 (permalink) Old Jun 2nd, 15, 08:49 PM Thread Starter
MIKE
miket1's Avatar
Thanks for all the response & info. ,
The machine shop set piston wall clearance at .004 ,
I ordered Cometic 4.060 bore, .027 compressed thickness, this will give .034 to .035 quench area, the #140 cam has a lot of overlap & duration to bleed off a little compression, the tight quench helps prevent detonation, I have built several 302 engines over many years using these tolerances and had very good performance and all were very reliable,
miket1 is offline
post #9 of 12 (permalink) Old Jun 2nd, 15, 09:14 PM
Lynn
I think you are right on.
Take a video clip when you get her running. I want to hear it.
Lynn
post #10 of 12 (permalink) Old Jun 2nd, 15, 10:12 PM Thread Starter
MIKE
miket1's Avatar
OK Lynn, I will try to get that, it may be 6 weeks or so before all completed.
miket1 is offline
post #11 of 12 (permalink) Old Jun 19th, 15, 02:33 PM Thread Starter
MIKE
miket1's Avatar
My 302 is assembled w/ all the original internals and other stuff it was built with and almost ready to install, still need to paint it and install new clutch ,maybe couple weeks out.
miket1 is offline
post #12 of 12 (permalink) Old Jun 19th, 15, 04:08 PM
Anne
I hope they didn't mill off the block numbers ?
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
