Glazed cylinder walls - Team Camaro Tech
post #1 of 10 (permalink) Old Jun 1st, 15, 10:23 AM Thread Starter
Ron
I just found out what was causing my oil smoke/consumption; the cylinder walls are glazed. There was a lot of sludge buildup and it looks like it wasn't cared for previously. They tell me it would be better to bore the cylinders with new pistons than just honing it. What do you guys think? I want it done right but not spend a fortune but if installing new pistons is the way to go then so be it. I trust your guys opinion.
rjg67rs is offline
post #2 of 10 (permalink) Old Jun 1st, 15, 10:29 AM
Camarodude67
Re: Glazed cylinder walls
If you are going to that process I would go .30 and new pistons and whatever else that needs to be done, do it right and not worry about it in the future.
camarodude67 is offline
post #3 of 10 (permalink) Old Jun 1st, 15, 11:08 AM
Rich
X2 REALLY no fun having to do it a second time
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #4 of 10 (permalink) Old Jun 1st, 15, 12:14 PM Thread Starter
Ron
Thanks, that's what I'll do and be done with it.
rjg67rs is offline
post #5 of 10 (permalink) Old Jun 1st, 15, 03:24 PM
Bob
Honing rarely deglazes a cylinder completely, especially if its bad. As said above do the .030 over and never look back.
68 RS/SS 496 T56 6 Speed Tuxedo black w/ white bumblebee. Strange Dana 60, Spicer 3.73 Helical Gears
mxquattro is offline
post #6 of 10 (permalink) Old Jun 1st, 15, 04:20 PM
Steps
MEASURE everything THEN decide what action...
The usual problem that a re hone doesn't fix a glaze is that the re hone , like the 1st has not been done correctly in the 1st place... be it the right speed, angle, or grit at fault.
Or simply that when bedding in in those few 1st minutes the rpms oil whatever has not been correct.
Its like when one adds up a long column of numbers gets it wrong.. then re adds going in the same direction and still make the same mistake.
Before ANY machine work is done on ANYTHING... measure everything up 1st.. ONLYTHEN proceed with decision making
Steptoe is offline
post #7 of 10 (permalink) Old Jun 1st, 15, 06:56 PM
Bob
When I worked at a machine shop, Steptoe, we have found numerous times that honing doesnt fix it permanently. The metal changes deeper than the visible glaze. I agree 100% to measure first before a bore, there is no going back. Do the minimum required for sure.
post #8 of 10 (permalink) Old Jun 2nd, 15, 02:43 PM
Steps
Agree..I spent a bit of time in the ACL labs here.. a real eye opener experiance....
I think u will find the the depth of the annealing is directly related to the mixture and timing of the engine....if ball park not a problem.. if not, one gets excessive temps...bedding in , bent skirts, cracked pistons become an issue....
Considering it is a common practice to drop a dizzy in rough ball park, then start turning the engine over twisting the dizzy, then have it fire way over advanced....and the VA most proberly still connected
from there, its an attitude "Ok is running leave the dizzy where it is, where is the timing light guys?" and its during this period cams rings etc get bedded.
Timing light found, hooked up and idle timing set.... NOT the total @ mid 3000K rpms....and if is the VA still connected.
Throw a lean mixture in on that...
Steptoe is offline
post #9 of 10 (permalink) Old Jun 2nd, 15, 05:42 PM
Anne
Just be sure that the shop you pick can final-hone the new .030" overbore with torque plates; a very important step.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #10 of 10 (permalink) Old Jun 2nd, 15, 11:18 PM
Steps
Yeah and match each piston to each cylinder/ hone... yeah these days piston manufacture is pretty damn good....but never assume anything
Steptoe is offline
