Knucklehead incident - Team Camaro Tech
post #1 of 24 (permalink) Old Jun 2nd, 15, 02:18 PM Thread Starter
Tony
I took off my distributor, carb, intake manifold and valve covers. The plan was to replace the intake, check springs in distributor and repaint the valve covers while they were off.
Ok, so while everything is ready to be reinstalled I decide (this where trouble starts) to empty radiator fluid and add all new antifreeze. Thinking that it can't hold more than two gallons I close valve at bottom of radiator and start away on refiling the tank with antifreeze. After two gallons I still don't see the fluid reaching the radiator neck. Again, I keep filling it until I hear a something. I look up and antifreeze is pouring out of a head port into the engine valley/top and disappearing into a hole. I then yell some choice words and stop.
Now my question is.....where does this hole lead? It is at the firewall/drivers side of the motor in the corner of that motor valley. My guess is the oil pan but is there another route that leads too?
I picked up some oil and a new filter but waited to drain it until I get this question answered. I hope it didn't go somewhere that requires removing heads or something.
1969 Camaro SS350, original motor/12 bolt/interior and build sheet in Fathom Green.
TClovis is offline
post #2 of 24 (permalink) Old Jun 2nd, 15, 02:20 PM
Banned
Chet
Re: Knucklehead incident
That is an oil return hole. Drain the oil pan. No ifs, ands, or buts.
onefiness is offline
post #3 of 24 (permalink) Old Jun 2nd, 15, 02:47 PM
paul
Drain the pan now, let it sit with the plug out the bottom over night.
Then, fill with cheap-*** walmart oil of the correct grade and a new filter, don't drive it with the cheap oil but just let it idle and keep an eye on the temperature so you don't boil it up or anything.
Once its had a half hour or more of just sitting there let it cool for a bit and drain the oil again.
Refill with nice oil and drive on.
Keep an eye out for moisture making mayo in the top of the valve covers but I think after a flush and run you will be ok.
paulmanta is offline
post #4 of 24 (permalink) Old Jun 2nd, 15, 02:53 PM Thread Starter
Tony
Ok good. It scared the blank out of me when it happened. I'll take that plug out when I get home and drain it then. I can't wait to get the thing back together today.
TClovis is offline
post #5 of 24 (permalink) Old Jun 2nd, 15, 05:26 PM
Anne
LOL, don't feel bad. I've added oil with the drain plug out.
Makes quite a mess on an asphalt driveway.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #6 of 24 (permalink) Old Jun 2nd, 15, 06:09 PM
ZZ_430's Avatar
I've done worse things!
...like catching a car on fire at the place I worked.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #7 of 24 (permalink) Old Jun 2nd, 15, 06:37 PM
Bill
Whew! From the title I thought you had an accident which ruined an old Harley!
Speaking of Harleys, I once got distracted working on my bike, just after I had merely put the oil dipstick into the hole so I wouldn't lose track of it and not taking the time to actually screw it into place. Cutting to the chase, I must have scorched the shifter forks for second gear or something, whenever the bike gets hot the tranny gets stuck in second.
Then there was the time I used cooking oil to try and loosen the baffle in an upswept four-into-one exhaust system. (obviously not a Harley)
In other words: Don't feel bad!
67 RS in Japan.
"You can only be young once, but you can be immature forever!"
W-P Bill is offline
post #8 of 24 (permalink) Old Jun 2nd, 15, 08:15 PM
69-Pace's Avatar
Yeah we have all been on the bonehead express in the vip seat one time or another.
I'm a big fan of the oil rinse. As described drain replace filter, and fill with oil and stir a bit but not much just enough time to get everywhere and long enough to reach temp and burn off any water in the system. The dump and replace filter and add driving grade oil.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #9 of 24 (permalink) Old Jun 9th, 15, 09:37 AM
The result of drinking too many PBRs while installing PBRs.
BPOS is offline
post #10 of 24 (permalink) Old Jun 9th, 15, 09:54 AM
I've hard of metallic brake pads, but that is going to the extreme.
Mike - '68 Camaro with lots of stuff done to it.
Mkelcy is offline
post #11 of 24 (permalink) Old Jun 9th, 15, 10:35 AM
Good thread! We have to laugh at our own dumbassselfs sometimes. Here's my latest one.
I was recently cleaning out the garage and found half a gallon of blue windshield cleaner fluid. I decided to dump it in my wife's car. As soon as it went "glug" I realized it was used 90W. Now I had a windshield washer resovoir with 90W in it.
First I panicked...then I considered phoning a friend... then I tried to siphon it out. No luck. Then I finally decided to thin it out with a quart of mineral spirits and use the windshield washer pump to pump it out into a jug. Then I ran about 3 gallons of soapy hot water through it.
It seems to have worked.
Melrose RS is offline
post #12 of 24 (permalink) Old Jun 9th, 15, 11:30 AM
Arch Stanton's Avatar
Dont feell bad. I forgot to put new oil filter on while doing oil change. 5 quarts of Mobil 1 dumped on driveway wondering why oil pressure isnt coming up. D'oh!
Arch Stanton is offline
post #13 of 24 (permalink) Old Jun 9th, 15, 12:36 PM
paul
I built an engine, on the stand, all done and assembled I put it on the bench and put the flywheel, clutch and gearbox on.
Put it in the car and as I always do I wired the starter and left the spark plugs and rocker covers off, then filled with oil with a nice new filter.
Cranked it up to get oil pressure and do a check on circulation, make sure it was getting up to all the rocker studs.
This time no oil, anywhere. But a puddle on the floor.
Bung plug in, filter ok.
Rear seal failure ? Engine out again, gearbox split off and flywheel back off.
Ahhh, yes. Forgot to fit a rear seal because I built it on the stand and you cant see that bit when you have it on a stand.
Good job I built it with loads of assembly lube on everything.
post #14 of 24 (permalink) Old Jun 9th, 15, 09:03 PM
Darn good thing you didn't start it with antifreeze in the oil - it will eat your bearings up. You are probably OK because the oil will float on top of the antifreeze, which means the antifreeze should have been on the bottom of the pan. Still, you probably have a 5 quart pan, and 1 gallon = 4 quarts, meaning you may have had enough AF in there to get above the level of the crank. Go real easy on it until you are sure that all of the AF has been flushed out and burned off.
1967 RS/SS 350 Conv - triple black, 4sp, tach & gauges
1969 VN-built RS/SS 396 Conv - Garnet Red/Black, 4-sp, tach & gauges
RSSSfanatic is offline
post #15 of 24 (permalink) Old Jun 10th, 15, 01:37 PM
DT
Donny
DT's Avatar
I'm afraid I have been here too AL, sober mind you, just did it in the dark.
DT is offline
