I have a 1969 Camaro with a 327, 4 barrel carb, electronic points, new voltage regulator, new Delco starter, battery was checked and is in good shape, had the alternator bench checked and is ok. The car starts real good when the engine is cold. But after driving for some time and the engine is good and hot, she just won't turn over. When I turn the ignition I can here the starter click like it's getting fire but it wont even spin. After the engine cools it starts up fine. I've checked the ground and connections and everything looks fine.
I can't figure this one out. Any ideas would be appreciated.
