edelbrock performer RPM setup? - Team Camaro Tech
post #1 of 12 (permalink) Old Dec 13th, 04, 09:11 PM Thread Starter
Is the edelbrock performer RPM setup any good? I have heard both good and bad things about edelbrock's stuff, but was wondering what you guys thought since it is going on my newly purchased '76 Camaro.
Thanks in advance for any help,
Joe
'96 formula- P&P heads, CC305 cam, 150 shot nitrous,...<br /><br />'76 camaro 350, holley 4brl carb, weiland intake, ...
96birdlt1 is offline
post #2 of 12 (permalink) Old Dec 14th, 04, 03:06 AM
Eric
Depends on your engine combo. The RPM manifold is definately one of the better manifolds for an engine with a 2000-6000 power band.
Eric68 is offline
post #3 of 12 (permalink) Old Dec 14th, 04, 03:29 AM
Talking
I think the consensus is the package is pretty good, except for the CAM, much better cam alternatives on the market!
kz1000ltd is offline
post #4 of 12 (permalink) Old Dec 14th, 04, 02:21 PM
I agree with kz. Intake and head are good, but there are better cams to be had. I don't know how the Edelbrock heads compare in price to other manufacturers. You might be able to find a similar head elswhere for less.
dnult is offline
post #5 of 12 (permalink) Old Dec 15th, 04, 06:11 AM
Greg
I loved the Perfomer RPM cam and intake on my set up. With AFR heads the combo took me to [email protected] at 3450#.
I did have a problem with the lifters. I was swapping the heads and noticed that a couple of the retaining clips that hold the plunger assembly together had come loose. Never had any problem from it, but I swapped in a set of Comp lifters just to be safe.
I think you'll like it.
69 Camaro, 3650lbs., 400ci, TH400, Coan 10" converter, 3.50 gear
D1SC, pump gas, 9:1, 10 PSI, Water/Meth injection
1.325 60', 5.988 @ 115.4 (carb)
Switched to Super Sniper EFI 2019
Greg O is offline
post #6 of 12 (permalink) Old Dec 15th, 04, 08:40 AM
I guess I should qualify my answer a bit. What I'm looking for is good street manners and low-mid torque. The RPM made the bottom end a bit soft for my taste. If I take mine to the quarter mile, it will be for fun once in a blue moon. So perhaps what the RPM cam provides is not what I'm looking for.
dnult is offline
post #7 of 12 (permalink) Old Dec 15th, 04, 02:22 PM
Lonnie
Did you have the same stall as now? That's a good ET for 113. 60 ft about 1.59?
67 Camaro [email protected], [email protected], 1.455 60ft 421sbc
Lonnie67 is offline
post #8 of 12 (permalink) Old Dec 16th, 04, 04:10 AM
Greg
Lonnie, Yep, same converter. The converter is a blessing and a curse. It's real slippy (i.e. inefficient) so it has always made for great e.t. (due to high stall) but not much MPH (too much slip at top end).
When I had a tighter converter I ran 11.96 but at a slightly HIGHER MPH!?!?
I have spoken to ATI, BTE and others about getting a more efficient 8" and all of them say they could get me a little more MPH but couldn't really improve e.t. so I just keep my $700+ in my pocket. It's only a problem in the 1/4 because I run out of RPM but I do 98% of my racing in the 1/8th.
Greg O is offline
post #9 of 12 (permalink) Old Dec 16th, 04, 09:05 AM
KZ is right the Cam sucks but the rest of the package is pretty good. But i will say i am not a big fan of thier small block heads i think for the price you can do much better.
69 Camaro RS, 383ci,10.5-1 AFR 195's ported, Comp 286HR, 4340 forged Crank & Rods, JE Pistons, RPM Airgap, Holley 750 HP carb, 350 turbo w/ shift kit, 3000 Coan, Be cool, caltracs,12bolt 355 eaton posi..Best E.T. 12.22 @ 112
69CamaroRacer is offline
post #10 of 12 (permalink) Old Dec 17th, 04, 05:02 PM
Lonnie
69CamaroRacer, very nice and clean 69. What's your ET goal with the new 383? Just curious. [img]graemlins/thumbsup.gif[/img]
Lonnie67 is offline
post #11 of 12 (permalink) Old Dec 18th, 04, 07:26 AM
Thanks Lonnie Thanks for the complement. I would be very happy with anything in the 11's. I am hoping to get 500hp 500lbs of torque out of the new 383 so if the power is there I think that the mid 11's are do-able. I as far as suspention goes I have 90/10's up front and new multi leafs and 50/50's in the rear with Cal track bars. In the past the car has been exceptionaly responsive to mods as I was able to click off a corrected 13.2 @103 with only 230 rwhp. and 280 rwtq. If for some reason I can't get to my goal naturaly I will just spary a 100 shot. For right now I would just be happy to be able to drive it again. It has been an entire year sice I started my build and I am in the home streach of completion. Come hell or high credit card bills I will be terrorizing the rice rockets and the frod clan at the strip come spring!
post #12 of 12 (permalink) Old Dec 19th, 04, 05:50 AM Thread Starter
what cam would you guys suggest on a 350? I would like some good power and a good muscle car lope.
Joe
