Gas tank cap - Team Camaro Tech
post #1 of 8 (permalink) Old Jun 4th, 15, 10:09 PM Thread Starter
Gas tank cap
The gas tank cap is under a lot of pressure whenever I remove it to fill up the tank. Is this normal? This is on an original 1969 SS with 396 engine; car runs fine.
pfahey is offline
post #2 of 8 (permalink) Old Jun 4th, 15, 10:23 PM
Vega$69's Avatar
Re: Gas tank cap
Normal
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 8 (permalink) Old Jun 5th, 15, 06:39 AM
Re: Gas tank cap
Agree very normal.
EcklersCamaro is offline
post #4 of 8 (permalink) Old Jun 5th, 15, 07:01 AM
Timmy
Re: Gas tank cap
Does the Stock Cap Vent Both ways ?
Would the Summer Heat build enough pressure to push Fuel and Vacuum when Cools down.
I do realize these Systems have lasted 40+ years too, just Thinking - Hmm
Timmy
Name:	1969 Camaro Fuel Tank Install 004.jpg
1969 SS/RS Coupe 427BB 700R4 12 Bolt 4:11 A/C, High School Resto Mod
November 1968 Build Date
french69ssrs is offline
post #5 of 8 (permalink) Old Jun 5th, 15, 07:34 AM
Re: Gas tank cap
C'mon Timmy! Now you're just showing off the rotisery and sweet ride on it!! haha!! Sorry, I'm just gealous!! Nice tank!!
brian2013 is offline
post #6 of 8 (permalink) Old Jun 5th, 15, 07:39 AM
Vega$69's Avatar
Re: Gas tank cap
Stock cap vents in only. And no problem in the summer.
Vega$69 is offline
post #7 of 8 (permalink) Old Jun 5th, 15, 08:45 AM
69-Pace's Avatar
Re: Gas tank cap
Sealed systems were emissions controls added in the early 70's and in place by 74 for GM if I remember right. The pre sealed system caps used in 67,68 69 Camaros allowed air in the tank so the pressure of fuel being pulled out by the engine wouldn't cause a vacuum. As said the temperature can greatly effect tank pressure. If the beads in the cap that form the vent are damaged you can get a partial collapsed tank if there is a sudden temp change such as adding cold fuel to a hot empty tank. Usually these dents pop out again once the fuel reaches road temps. But still fund and scary to watch.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #8 of 8 (permalink) Old Jun 6th, 15, 04:02 PM
Re: Gas tank cap
Back went I was questioning the tank pressure in my 69, I called Stant to discuss, they said the cap will release pressure after a certain psi, can't recall what psi they said though. I confirmed it at the time using a rubber tipped blow nozzle with regulator set to the psi they said, and it did indeed blow back thru.
schnide is offline
