need picture of small block engine mounts on frame - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 26th, 04, 09:18 AM Thread Starter
mark
I have a 67' with a small block and the stud for my clutch linkage is a quarter inch from the fire wall. The engine mounts on the frame don't look right to me so I'm not sure if there the correct ones. If anyone has a picture of what they look like I'd appreciate it.thanks
sick67 is offline
post #2 of 8 (permalink) Old Dec 26th, 04, 02:46 PM
here ya go:
They were to show the guldstrand mod, but the mounts are there
post #3 of 8 (permalink) Old Dec 27th, 04, 06:39 AM Thread Starter
mark
yeah those are the ones I have. Is your stud for the clutch linkage almost rubbing on the fire wall.the z-bar rubs on the wall a bit. Thanks for the pics.
sick67 is offline
post #4 of 8 (permalink) Old Dec 27th, 04, 10:33 AM
Check the condition of your body mounts. If the bushings are shot and the holes are rusted out that subframe could be shifted to the rear. Just a thought.
69X11SS is offline
post #5 of 8 (permalink) Old Dec 27th, 04, 03:01 PM
No, my clutch linkage has been fine since I put it in 5 years ago, and until a week ago, my body mounts were shot.
I never really looked at the clearance, car was together when I converted from pg, just know it don't hit nuttin. Can't check now, engines kinda far away from the frame...lol
Hmmm....do i remember reading here in the past week, something about if you put the crossmember in backwards your trans will sit high? That could do it.
post #6 of 8 (permalink) Old Dec 27th, 04, 06:39 PM
Hi ! I just wanted to add that a 327 or 307 car and a 350 or 302 use different frame mounts. Not all small blocks used the same mounts. This may or may not be causing your problem, but I did want you to be aware of this.
TJS69 is offline
post #7 of 8 (permalink) Old Dec 28th, 04, 03:06 PM
mine are 327
post #8 of 8 (permalink) Old Jan 2nd, 05, 06:56 PM Thread Starter
mark
Well I finally solved the problem. This is my first american car and I bought it as a roller so I'm learning as I go along. I had the stud for the linkage in the side of the bellhousing. I went and looked at my buddies spare 350 and there was a spot above the oil filter that was not drilled in my 400. So I pulled the steering column and now have a spot drilled and tapped after a nervous 2 hours.Thanks for the help
sick67 is offline
