need help selecting a cam for my 383 - Team Camaro Tech
post #1 of 23 (permalink) Old Jun 7th, 15, 11:09 PM Thread Starter
Jerry R.
jr68's Avatar
I bought a 383 short-block from Summit, then picked up a pair of used World heads (iron) with big valves, they were recently redone and are in nice shape. I'm about to order a 750 cfm Quick fuel carb with mechanical secondaries.
Specs on the rest.
Turbo 400 trans just rebuilt
3.36 posi rear
255/60/15 tires
10-1 compression
headers
power brakes
pump gas
dual plane aluminum manifold
dont have a torque converter yet but probably 2200 rpm or somewhere close
looking for nice cruiser with some snort off the line but want to be able to pass multiple cars easily on the hi way
thanks in advance
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #2 of 23 (permalink) Old Jun 8th, 15, 03:37 AM
Re: need help selecting a cam for my 383
I like this...roller cam BTW
http://www.compcams.com/Company/CC/c...?csid=181&sb=2
68 Camaro~LSx ~all motor
post #3 of 23 (permalink) Old Jun 8th, 15, 04:16 AM
Nice choice of camshaft.
post #4 of 23 (permalink) Old Jun 8th, 15, 03:14 PM
Chaz
I had a double pumper with an automatic once and wan't happy with it at all. I have an AED in my car now but I'm also running a Tremec 5 speed now. If I was running a Double Pumper I'd want gears and stall at least! You gotta get that beast to rev quick!
68 Camaro
Some mods...
68SSlemans is offline
post #5 of 23 (permalink) Old Jun 8th, 15, 04:44 PM
Keith
I went with an XR282HR form comp cams in my 406....Makes decent vacuum and a ton of torque and power...
Keith
1967 Camaro
Muncie M-20
GM 8.5, 3.73 posi
keithl1967 is offline
post #6 of 23 (permalink) Old Jun 8th, 15, 06:40 PM
Tom Anderson
You cant go to high of lift cam you will lose vacuum to brakes and that sucks plus you will have to run a big stall which kills the mileage. I have made those mistakes so go smaller like 485 lift and you will be much happier
socal_tom is offline
post #7 of 23 (permalink) Old Jun 8th, 15, 09:21 PM Thread Starter
Jerry R.
jr68's Avatar
thanks for the replies guys.
I read up on both of the comp cams you suggested.
Do you think I am going to have a problem compensating for those 336 gears?
jr68 is offline
post #8 of 23 (permalink) Old Jun 9th, 15, 12:35 PM
Chaz
I have power brakes and run a high lift cam w/o a vacuum resivoir. Lift on my cam is 525/540. I believe the overlap and duration affect the vacuum more
The reason you need the lower gears with the big cam is to compensate for the lack of low end response. With your current setup you will most likely be happier with a smaller cam and a vacuum secondary carb. That's my experience
68 Camaro
Some mods...
post #9 of 23 (permalink) Old Jun 9th, 15, 02:27 PM
You are correct, overlap and duration effect vacuum, higher lift gets more charge in and out of the heads/cylinders to a point and moves the peak horsepower to a higher rpm.
NH69Z28RS is offline
post #10 of 23 (permalink) Old Jun 11th, 15, 05:23 PM
Kim
Fill this in and see what Mike Jones says, if you want a cam for your engine. Shelf cams are generic grinds, made to work but not necessarily the best for your engine/car.
http://jonescams.com/street-performance/
kimosabi is offline
post #11 of 23 (permalink) Old Jun 12th, 15, 10:25 AM
Chris
Specs on the rest.
3.36 posi rear
255/60/15 tires
10-1 compression
headers
power brakes
pump gas
thanks in advance
Which world heads did you get?
Chris
cstraub is offline
post #12 of 23 (permalink) Old Jun 12th, 15, 10:31 PM Thread Starter
Jerry R.
jr68's Avatar
I know right now that I cant come up with half of that info like intake or exhaust flow, and for those reasons I'm out
jr68 is offline
post #13 of 23 (permalink) Old Jun 13th, 15, 03:36 PM
A HR cam with 210-215* IN dur will give oodles of TQ for those gears and stockish TQ converter. 5* Less dur if more economy is wanted.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #14 of 23 (permalink) Old Jun 15th, 15, 09:19 PM Thread Starter
Jerry R.
jr68's Avatar
the only writing on the head is this
jr68 is offline
post #15 of 23 (permalink) Old Jun 17th, 15, 01:48 PM
Chris
Take a picture of the combustion chamber and I can tell you for sure sir.
Chris
cstraub is offline
