Exhaust sounds - Team Camaro Tech
post #1 of 15 (permalink) Old Jun 8th, 15, 11:53 AM Thread Starter
Darrell
cook_dw's Avatar
Exhaust sounds
If there is another thread already like this then admin please delete.
I got to thinking the other day that when I was working on which exhaust system I wanted to put on my car I wished there was a thread or website I could have gone to and listened to some different sound clips.. Maybe we can do this here and make it a sticky?
List your engine size, cam, exhaust size, x-pipe, h-pipe or n/a, muffler brand, muffler type and/or part # and where the exhaust exits the car and a video clip.
396 BBC
Comp Cams Magnum H292
2.5"
x-pipe
Pypes
Crossflow - MVR100
exits in stock location
http://vidmg.photobucket.com/albums/...psrmcgcu6m.mp4
cook_dw is offline
post #2 of 15 (permalink) Old Jun 8th, 15, 12:12 PM
Smile Re: Exhaust sounds
http://www.dynomax.com/sounds-of-dynomax/
http://www.magnaflow.com/sound_files.asp
https://www.youtube.com/user/Flowmaster
http://www.gardnerexhaust.com/
TJS69 is offline
post #3 of 15 (permalink) Old Jun 8th, 15, 03:55 PM
jared
Re: Exhaust sounds
You tube. Jared freemyer. You will hear a set of summit racing mufflers.
jcfcamaro is offline
post #4 of 15 (permalink) Old Jun 8th, 15, 04:32 PM
Steps
Re: Exhaust sounds
Want a good sound out of a Chevy?
Chevys by nature.. timing sequence etc.. sound good naturally....dodges ok, fords, well need a lot tinkering.
Just do not use stainless.
Use heavy walled pipe
Run a balance pipe.
Throw in a couple elcheapo mufflers... far too much is made of mufflers and quality of sound.. very much a marketing propaganda BS thing... again.
Then re tune the idle timing and mixture circuits to suit.
Steptoe is offline
post #5 of 15 (permalink) Old Jun 8th, 15, 09:25 PM
mike
Re: Exhaust sounds
Dynamax here, procharged 496 3" dumps behind the tires like stock. I really like the sound, it is mellow until you step on it.
bigblockragtop is offline
post #6 of 15 (permalink) Old Jun 8th, 15, 09:28 PM
Jerry R.
jr68's Avatar
Re: Exhaust sounds
Darrell, my sound is right in my sig.
as for specs,
327
750 Holley double pumper
air gap manifold
2.02 double hump heads ported and polished
hooker headers
2.5" magnaflow duals with X-pipe
thats my whiney Muncie you can hear in neutral
click below to listen . . . .
my Magnaflow X-pipe system sound clip, click the link
jr68 is offline
post #7 of 15 (permalink) Old Jun 9th, 15, 08:08 AM
Anne
Re: Exhaust sounds
Originally Posted by cook_dw View Post
396 BBC
2.5"
x-pipe
Pypes
Crossflow - MVR100
How loud is your system ?
Here is what I'm using : 2-1/2" mandrel-bent system that is basically just like the stock system :
http://www.jegs.com/i/Dynomax/289/89021/10002/-1
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #8 of 15 (permalink) Old Jun 9th, 15, 08:52 AM
kevin
Re: Exhaust sounds
the sound track of mine in my signature
383
comp cam 252 duration @ .050
hooker super comp headers
pypes stainless x pipe
qtp electric cutouts
summit 2.5" stainless pipe exiting at the back
no mufflers
flat tire is offline
post #9 of 15 (permalink) Old Jun 9th, 15, 09:53 AM Thread Starter
Darrell
cook_dw's Avatar
Re: Exhaust sounds
Its not bad at cruise but WOT is pretty rowdy..
cook_dw is offline
post #10 of 15 (permalink) Old Jun 9th, 15, 07:03 PM
PA Camaro Guy's Avatar
Re: Exhaust sounds
Here's a recommendation I've never seen on this board so far... I use Moroso Spiraflows. They have a great rumble at idle but not annoying loud for the street... When you step on it look out...
383
234 degrees duration, 110 deg lobe separation
H-pipe, 2,5"
Turn downs after mufflers and before rear axle
Will try to get a clip.
1969 Camaro 383
2.02/1.63 & 234/244 Vortec
TH350 / 12 bolt 3.73
PA Camaro Guy is offline
post #11 of 15 (permalink) Old Jun 9th, 15, 08:34 PM
TJ
Re: Exhaust sounds
Electric cutouts with the best of both worlds!
ttwo is offline
post #12 of 15 (permalink) Old Jun 13th, 15, 10:50 PM
Bobby
Re: Exhaust sounds
Mines in the sig too.
Stock 300 horse 350, custom headers and Dynomax Ultraflow.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #13 of 15 (permalink) Old Aug 12th, 15, 05:47 PM
Mickey
Moonpie's Avatar
Re: Exhaust sounds
Hey TTwo....Sounds good. Which cutouts are you using? Like 'em? I made up my made a couple weeks ago to install cutouts so am now trying to get opinions etc.
Moonpie is offline
post #14 of 15 (permalink) Old Aug 13th, 15, 03:13 PM
rude dog
Re: Exhaust sounds
Lawrence--are you using that system with headers? does the exhaust dump out behind the rear wheels or under the rear end?
1967 Camaro RS
randf is offline
post #15 of 15 (permalink) Old Aug 13th, 15, 03:51 PM
Anne
Re: Exhaust sounds
The pic of the system appears that the tailpipes exit at the rear like a 69. My headers are hedman elites with 1-3/4" primaries (BBC).
That system is on backorder and should be available late this month. http://www.jegs.com/i/Dynomax/289/89021/10002/-1
Autozone and Advance Auto typically offer 20% off and free shipping.
Ronald Reagan
