backfiring when engine cold - Team Camaro Tech
post #1 of 5 (permalink) Old Jun 10th, 15, 03:47 PM Thread Starter
bob
I have a 1969 camaro with a 427 motor, double pumper holley carb. When I first start and drive the car it backfires and feels like its running on 6 cylinders. What could cause this? Thanks for your help.
bobanger is offline
post #2 of 5 (permalink) Old Jun 10th, 15, 06:02 PM
scblucam's Avatar
Re: backfiring when engine cold
Does it clear up after warming up? Choke?
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 5 (permalink) Old Jun 10th, 15, 08:23 PM
69-Pace's Avatar
And don't forget that there are two states of "backfire" one is pre ignition in the carburetor and this is caused by timing issues most of the time, and the other is post ignition where raw fuel is ignited in the exhaust system having not been ignited in the cylinder during the ignition sequence of the crank.
Pre-ignition through the carb often includes flame ups from the throat of the carb.
So where does yours backfire from?
Check you initial timing and choke idle speed and vacuum advance setting.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 5 (permalink) Old Jun 13th, 15, 03:46 PM
Backfiring = a lean condition. Adjust the choke.
71 Camaro 355 NA
11.1650 @ 119.30
1.5028 60'
hhott71 is offline
post #5 of 5 (permalink) Old Jun 13th, 15, 06:10 PM
Banned
Chet
Backfiring a lean condition? Always? Backfiring out the exhaust is usually caused by late timing.
onefiness is offline
