speedo drive for six speed - Team Camaro Tech
post #1 of 8 (permalink) Old Dec 6th, 00, 08:53 AM Thread Starter
Anybody have a suggestion how I can drive the original speedometer with a six speed trans in my 67 convertible?
Mark Perkins
ASE Master Auto/Truck
67 RS Convertible
AUTODR is offline
post #2 of 8 (permalink) Old Dec 6th, 00, 09:56 AM
Jags That Run can modify your tail shaft housing to accept the stock speedo cable. Expensive work, I think they want around $300 to do it!
Joseph
Joseph is offline
post #3 of 8 (permalink) Old Dec 6th, 00, 02:42 PM
There is also a company that makes a device called the cable X connection (or connector)
this takes a digital signal and converts it to drive your original speedometer... I think you can do a search of the internet and find more information. Or you might be able to a search on this site. Are you wanting to keep the original speedo? If you are not concerned about originality, you can always go with an Auto meter electronic speedo that will only set you back about $187.. A little cheaper compared to the alternatives: JTR Conversion $295.00 Cable X connector $300..
Go69 is offline
post #4 of 8 (permalink) Old Dec 6th, 00, 05:13 PM
If you want to do it once and not have to worry about it, get the jags that run modified tailhousing. It works good and you don't have to worry about it failing. I bought one of the conversion boxes and it is a pain in the butt. Now i have the modified tailhousing.
Jeffro is offline
post #5 of 8 (permalink) Old Dec 6th, 00, 06:48 PM Thread Starter
For whatever reason I think I want to keep the original speedo. I dont know If an aftermarket speedo would be out of place in what (I Hope) will be an original appearing dash. Then again, if I could figure out how to install an aftermarket speedo and guages that would probably be OK too.
Mark Perkins
67 RS Convertible
AUTODR is offline
post #6 of 8 (permalink) Old Dec 7th, 00, 05:01 AM
I have an article from a mag that tells how to install Autometer gauges (speedo and tach)in a 67 or 68 dash it pretty easy. E-mail me with your address and I will mail a copy to you.
Sean James
67 camaro convertible
454 - 700r4
4:10 12 bolt
69 Firebird
mo67cam is offline
post #7 of 8 (permalink) Old Dec 7th, 00, 04:20 PM
It's super easy to install 5" autometer gauges in a 67-68 dash. Drop the steering column, remove all the screws to the "pod" then disconnect the electrical and it will pop right out.
Then undo the screws holding the metal gauges to the plastic "pod" and you have the shell.
From there slide the speedo and tach through the front, and bolt the brackets to the back. Wire it up and put it back together and- PRESTO!! Custom gauges. I did this in my 68 in about 25 minutes. i used Auto Meter Phantom gauges with electric speedo so it would work with my VSS on the T56.
Tyler
1968 RS/SS Camaro w/ 94 vette LT-1 and T56 six speed, Cal-Tracs, Baer 12" crossdrilled brakes 17" rims, ect....
<A HREF="http://home.earthlink.net/~speedracer68/tyler.htm" TARGET=_blank>
My 68 with LT1 and T56</A>
Teetoe_Jones is offline
post #8 of 8 (permalink) Old Dec 7th, 00, 07:43 PM Thread Starter
Cool, thanks for the info.
Mark Perkins
67 RS Convertible
AUTODR is offline
