67 327 oil filter bypass valve - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 13th, 15, 06:13 PM Thread Starter
Romeo
I have a stock gm #3959104 5 oil bypass adapter and was wondering if there is a gasket between the block and adapter as I cant find one
tekin is offline
post #2 of 7 (permalink) Old Jun 13th, 15, 06:54 PM
Bill
Re: 67 327 oil filter bypass valve
Yes, there should be a gasket between the two surfaces. I have not seen this gasket in a gasket set in decades.
Bill
sbcBill is offline
post #3 of 7 (permalink) Old Jun 13th, 15, 06:56 PM Thread Starter
Romeo
where do you think I can find it and I am not sure how to post a pic
tekin is offline
post #4 of 7 (permalink) Old Jun 13th, 15, 08:59 PM
Bobby
Gasket paper and trace out the adapter on it, use an X-acto knife to cut it out.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #5 of 7 (permalink) Old Jun 13th, 15, 09:21 PM Thread Starter
Romeo
but the prob is the valve is in the way of the gasket going around and if you see what I mean google that part number and you will see it
tekin is offline
post #6 of 7 (permalink) Old Jun 14th, 15, 05:51 PM
Bill
If you flip the valve over you will see that the valve contact surface is actually quite small approximately 1 1/2" to 2" in size. The gasket surface is only slightly larger than the span of the valve attachment bolts. IIRC there is also a slight raised ridge in the die casting to help the valve seal against the block. This should help you see the shape of the gasket. I have also used gasket paper to fab my own. I hope this helps.
Bill
sbcBill is offline
post #7 of 7 (permalink) Old Jun 14th, 15, 11:09 PM Thread Starter
Romeo
ok that is fine I just took the gasket the hole circle of the valve and just center punched a hole of 1/2inch to let the oil flow through it if you like I can send you a pic
tekin is offline
