12 bolt to posi - Team Camaro Tech
post #1 of 5 (permalink) Old Nov 30th, 00, 07:25 PM Thread Starter
hi. Whats the easiest and cheapest way to turn my pathetic single wheel spinning 12 bolt into a streetable posi? thanx.......NIK
nix69 is offline
post #2 of 5 (permalink) Old Dec 1st, 00, 03:52 PM
Hit the junkyards, and find a used posi unit and your there.
nogo is offline
post #3 of 5 (permalink) Old Dec 1st, 00, 06:50 PM
Freddie
The easiest way is to put a Lock Right kit in it. You don't have to do any shimming or re-set the backlash for this one. A Eaton posi is very good, but you will have to shim it to set the backlash and bearing preload. DO NOT weld the differential gears or put a mini spool in it. These are very dangerous on the street. You will almost surely break something and crash and hurt someone.
'69 RS/SS396 pro street
427/4spd/9"
big gear head is offline
post #4 of 5 (permalink) Old Dec 4th, 00, 10:34 AM
Come on guys, eveyone should drive atleast one welded rear on the street! That way they know why NEVER to do it!
Just kidding, welding is dangerous and mini spools are pretty weak. All they power is transfered through a single pin.
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
1987 Toyota Pickup 383 / 500 + HP 10.963 @ 119.95 Slicks / 11.997 @ 114.23 Radials
"Speed KILLS, so drive a FORD and live forever!"
http://personal.lig.bellsouth.net/~racer383/
Mark W. Winning is offline
post #5 of 5 (permalink) Old Dec 5th, 00, 03:51 PM
Matt
Had a friend that bought a 70 Merc. Grand Marquis with a big block, we welded the spiders in it, did burnouts for a couple months, then were driving around a corner one day, and the inside axle busted, sent us right into the wall. Best damn $200.00 he ever spent for a car, and for a joyride!
Bing
1956 Chev 150 2dr sedan 302ci
1965 Chev Malibu 2dr hdtp 496ci
1967 Chev Camaro 327ci
Check 'em out at: http://www.members.home.net/mgbing/cremcars.html
