knock knock where's it at ??? - Team Camaro Tech
post #1 of 10 (permalink) Old Apr 7th, 04, 02:30 PM Thread Starter
Unhappy
hey guy's long time no type!!!!!! [img]graemlins/waving.gif[/img]
I have a 87 suburban with a 94 vortec engine.
the engine has a terrible knock,I was hoping it was a bad converter but after unbolting that and still having the knock,I then knew it was a rod...wrong!
I pulled the pan and all the bearings looked great main and rod,I checked all to be sure.
Iam stumped!!!!!
it almost can;t be heard at idel,but just a little gas and it sounds like it's gonna blow.
one thing I though of if the dist was from the orginal 87 motor could there be a problem with the gear...maybe roller cam in the 94 motor I really don;t know.
thanks! for any thoughts though!!!
boy do I mis the 67 [img]graemlins/sad.gif[/img]
Will
"Drive it like you stole it"
2000 SS camaro daily driver(wifes)
Oncea3Fan is offline
post #2 of 10 (permalink) Old Apr 7th, 04, 02:41 PM
choptop's Avatar
The mid 90's vortec engines are famous for piston slap. Is the knock really bad or just audible enough to be annoying? I had a '94 Silverado with a 305 that I could hear piston slap in at idle. When cold I often thought there was a serious problem, but the truck is still going strong (in someone elses garage now though).
choptop is offline
post #3 of 10 (permalink) Old Apr 7th, 04, 03:03 PM Thread Starter
no this is a serious noise. I can't believe the bearing were so good.
this motor is said to only have 35k on it.
post #4 of 10 (permalink) Old Apr 7th, 04, 03:35 PM
i would have to agree with choptop,i had the same problem(piston slap)in my 89 pickup.i took the motor apart and found 3 pistons with broken rings.the guy that i bought it from didn't belive in putting oil in it.on mine it sounded like a rod knock but looking at the bearings i could see they were good.does it ge louder as u rev it?
emtcee1973 is offline
post #5 of 10 (permalink) Old Apr 7th, 04, 04:16 PM
ZZ_430's Avatar
Thumbs up
Me too, pistons can make a lot of noise...bad noise.
Wristpin(s) is another possibility.
Don ~ TC Member #15 ~
Don't mess with Texas!
ZZ_430 is offline
post #6 of 10 (permalink) Old Apr 7th, 04, 04:24 PM Thread Starter
way loud when you rev it,kinda sounds like something rapping on an exhaust pipe.
but really can;t pin point to one side or front to back.
post #7 of 10 (permalink) Old Apr 8th, 04, 09:31 AM
a 94 isn't a Vortec- it's just a one piece rear main seal 350 TBI engine with a flat tappet cam in it instead of a roller.
my cousin has a 94 Suburban with a 350, and it make a bit of a racket like a bad rod knock at startup for a few seconds, then quiets right down.
you don't plan sincerity.
novaderrik is offline
post #8 of 10 (permalink) Old Apr 9th, 04, 03:10 AM Thread Starter
I though all were vortec when they became F/I'd.
if it a stardard short block then the 350 from that 84 pick-up will go in with just a intake swap right?
thanks!
post #9 of 10 (permalink) Old Apr 9th, 04, 11:12 PM
there are differences from the older small blocks to the newer ones- the most notable two are the one piece rear seal and the angle of the 2 middle intake bolts on each side. so, with a flexplate that matches the year of the engine, and a little die grinder work on the 2 middle intake bolt holes in the TBI intake, it should be a fairly direct swap. of course, then you have to deal with the TBI computer maybe not liking the older engine...
post #10 of 10 (permalink) Old Apr 10th, 04, 01:50 AM Thread Starter
sshhhheeessss...........anybody want to buy a 3/4 ton suburban [img]graemlins/sad.gif[/img]
