Difference in Cowl Induction Breathers (Z28 vs SB) - Team Camaro Tech
post #1 of 12 (permalink) Old Jun 15th, 15, 04:23 PM Thread Starter
Larry
I notice there are two breathers listed for the cowl induction hood breather for a 69 Camaro.
I'm trying to find out the difference. Could it be the Holley carb on the Z and a Quadrajet on the 350? If so, what is the difference?
http://www.camarocentral.com/1969_Co...8_p/air-41.htm
http://www.camarocentral.com/1969_Co...0_p/air-42.htm
my70z is offline
post #2 of 12 (permalink) Old Jun 15th, 15, 05:19 PM
Rich
Re: Difference in Cowl Induction Breathers (Z28 vs SB)
The difference is due to the carb and intake. I think that the spacer ring for the seal is where the difference comes in to make up the differing height between the high rise intake/holley carb setup on the 302 and the Q-Jet/cast iron manifold on the 350. What are you running on your car? Probably best just to give Camaro Central a call to get the right combo for your ride.
69 Z/28 RS clone. Azure Turquoise. First car--owned for 32 years and counting.
Rich Lordo is offline
post #3 of 12 (permalink) Old Jun 15th, 15, 05:33 PM
69-Pace's Avatar
Correct the spacer is different.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #4 of 12 (permalink) Old Jun 15th, 15, 05:52 PM
Jon
The bend on the vent tube on the bottom side is different also. BB and Z28 have somewhere near a 45 degree bend but a 350 has a full 90.
Jon N
dyno jonn is offline
post #5 of 12 (permalink) Old Jun 15th, 15, 07:21 PM Thread Starter
Larry
It is a 69 with a 350 (383), Performer Air Gap and a Holley 750. Guess I should measure the height from the carb to the hood. Not sure what this would tell me tho. Guess I'll call and see what they recommend as I dislike sending parts back.
Thanks guy!
my70z is offline
post #6 of 12 (permalink) Old Jun 15th, 15, 08:00 PM
69-Pace's Avatar
There is an excellent thread here at Team Camaro that details the three versions of 1969 Camaro - Small Block L48, Small Block Z28 302, and Big Block 396, as well as the 70 Chevelle version, including dimensions.
Once you know the distance from carb throat to hood seal then you can see which spacer extension ring, and or intake/carb combinations you will need. You can also have your local metal fabrication shop build you a custom extension ring
69-Pace is offline
post #7 of 12 (permalink) Old Jun 16th, 15, 05:01 AM
Kevin
KevinW's Avatar
Here is the comparison thread https://www.camaros.net/forums/showthread.php?t=54696
Kevin
KevinW is offline
post #8 of 12 (permalink) Old Jun 16th, 15, 04:26 PM Thread Starter
Larry
Excellent information guys, thank you so much. I think a standard 350 assembly is what I am going to order.
Originally Posted by KevinW View Post
my70z is offline
post #9 of 12 (permalink) Old Jun 16th, 15, 07:47 PM
Gary
69Z28-RS's Avatar
If you have a small block with a high rise aluminum intake, you might want the shorter Z28 extension ring instead of the taller L48 extension ring..
Gary
69Z28-RS
Corvettes (5), Nomads (2), El Camino, etc
69Z28-RS is offline
post #10 of 12 (permalink) Old Jun 17th, 15, 05:17 AM
Kevin
KevinW's Avatar
Or no extensions at all.
Kevin
KevinW is offline
post #11 of 12 (permalink) Old Jun 19th, 15, 09:05 PM Thread Starter
Larry
Luck was on my side..... A buddy of mine dropped by last night with his 69 small block. I have never asked if he had the breather under his cowl hood but as it turns out, yes. So, off of his and on mine. No extension needed with an Edelbrock air gap and Holley 750. It mates up perfect. We used some baby powder on the seal and had a perfect imprint on the hood when opened back up. I might add, my engine bay smells like a baby nursery now.
Thanks for all the help guys.
my70z is offline
post #12 of 12 (permalink) Old Jun 20th, 15, 01:45 AM
69-Pace's Avatar
69-Pace is offline
