Valve covers - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 16th, 15, 11:53 AM Thread Starter
Barry J
Barry J's Avatar
Valve covers
Right now I have old chrome high profile vavle covers on that I've had for about 20 years.
I would like to change them.
Is there any reason why I can't switch to a low profile type??
Also, thinking on going with the black ones, will that look good with my orange engine and aluminum intake??
Barry
"Kids in backseats dont cause accidents.
..accidents in backseats cause kids!!"
Barry J is offline
post #2 of 7 (permalink) Old Jun 16th, 15, 11:55 AM
Re: Valve covers
Barry
It depends on the height of your rockers whether you can go with low profile or not. As far as color schemes, that's personal preference. Beauty is in the eye of the beholder and all that...
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #3 of 7 (permalink) Old Jun 16th, 15, 12:27 PM
Re: Valve covers
You only need a high profile cover to clear roller rockers with a STUD GIRDLE. You can fit roller rocxkers under a stock valve cover by buying short adjuster nuts (poly locks 3/8th inch shorter than the ones they include in all Roller rocker sets. Even though they make yoiu buy taller by a 1/4 inch smooth top poly-locks (hex at the bottom of the nut) to use a stud girdle. So you have to either byut a tall valve cover or a second set of poly-lock adjuster nuts.
It's almost as if the aftermarket is trying to make you buy more stuff instead of helping the hobbyist out.
Larger Dave
Larger Dave is offline
post #4 of 7 (permalink) Old Jun 16th, 15, 04:11 PM
Smile Re: Valve covers
I couldn't find the picture that I wanted, so ...
The valve covers that I like...
these covers, not so much !
TJS69 is offline
post #5 of 7 (permalink) Old Jun 16th, 15, 04:12 PM
mike
Re: Valve covers
If you have to they make spacers so you can run any valve cover.
bigblockragtop is offline
post #6 of 7 (permalink) Old Jun 16th, 15, 04:13 PM
mike
Re: Valve covers
Neither of those are low profile.
post #7 of 7 (permalink) Old Jun 16th, 15, 04:17 PM
mike
Re: Valve covers
Be careful with that second choice. I bolted them on and it turned out the way they made the notched out areas where it bolts down rubbed on my roller rockers. I never got out of the driveway. It wiped out a pushrod top because it made the roller rocker move sideways.
