327 Re-build question - Team Camaro Tech
post #1 of 5 (permalink) Old Jan 6th, 05, 10:29 AM Thread Starter
James
Send a message via Yahoo to james7773
Ok, I finnaly got my 327 out and on the engine stand. Before I pulled her out, I ran a compression test on it. 4 cranks, secondarys open on the carb, and all plugs removed. no less than 165 #'s per cylinder and highest was 175#'s. Im going to be putting a new cam, lifters and pushrods in it, and Im considering a complete overhaul. The engine ran strong prior to pulling it out. The only complaint I had was after sitting it would puff a little smoke. (valve seals I suspect) What would you do? Rebuild, or just clean her up, or clean her up and add new gaskets?
Thanks,
James
My 67 RS 327...its a work in progress.
james7773 is offline
post #2 of 5 (permalink) Old Jan 6th, 05, 10:35 AM
I'd do a valve job for sure.
Compression test is nice, so the rest is probaly ok. You might pull one or two rod caps and look at the bearings, small bits of emdebbed crap are ok, large sratchs or any copper showing are not ok. Check the ridge at the top of the cylinders, could be carbon here, scrape it off with a single edge razor to get down to metal. With comp like you got, rings and walls should be fine.
post #3 of 5 (permalink) Old Jan 6th, 05, 10:46 AM Thread Starter
James
thanks for the speedy reply Jim. Ill do what you suggested..valve job, etc. anyone else have thoughts? BTW..the main catalist for this is that the engine is absolutly filthy. One of the percs would be that the machine shop would clean er out for me!
James
post #4 of 5 (permalink) Old Jan 6th, 05, 05:07 PM
Time and money, James... comp at 170 +-5 says your walls, pistons, and rings are good, valve are sealing good too. The smoke is from bad valce seals, possibly worn guides, probably not.
Then on the other hand, if you do everything but boil the block and change the cam bearings, you can be in and out for 300 clams, with new rings and bearings, a quick hone, and everytihng clean and shiny. Another duce or so to do the heads and you're like new for 5.
If you take her down, watch that ridge, even a couple thousandths can catch a ring and break the ring land. Rent a ridge reamer to smooth it out if you have too. Take the rings off, put the piston in upside down, and check your clearance with a feeler guage, an inch down in the bore.
Really tho, the comp test says this bottom end is good.
post #5 of 5 (permalink) Old Jan 7th, 05, 06:47 AM
Codi's Avatar
I agree with Jim.
Daddy's Hot Rod.
Codi is offline
