Black smoke under hard acceleration - Team Camaro Tech
post #1 of 15 (permalink) Old Jun 17th, 15, 09:23 PM Thread Starter
Nate
Coming back from the car show today my friend was behind me at a stop. I ran wot to the top of 3rd gear. When we got back to my place my friend told me when I launched I had black smoke dump out of my exhaust. He said it only did it on the launch. I did a tune up a couple months ago with new plugs and rebuild the carb (Holley 600 4 bbl) while I had the plugs out I did a compression test all 8 cylinders were 148~150 the old plugs were not black, white or had any signs of bad burn. Put new plugs in. Re did the timing bc my carb had a vacuum leak. It's at 33* total. Engine is a 327 with stock heads, edlbrock intake, hei, mild cam. Mild engine. Vacuum is a 15hg steady. The car runs great, idles smooth. I have a m20 4 speed with 12 bolt rear, 3:31 gears with posi. I do have a slight chatter when starting from a stop (guessing my cam is not matched with the gear ratio??) my question is, is the black smoke under hard acceleration an issue? I believe it's a rich condition which could be fix by leaning it out a touch but otherwise the car runs great! And the plugs show it. Should I tune accordingly? and how would you recommend to?
Nhurt is offline
post #2 of 15 (permalink) Old Jun 17th, 15, 09:28 PM
69-Pace's Avatar
Re: Black smoke under hard acceleration
Sure it wasn't just dumping carbon from the exhaust system? Usually a second pass back to back at WOT reveals no carbon left, so no smoke screen.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 15 (permalink) Old Jun 17th, 15, 09:32 PM Thread Starter
Nate
That very well could be it, he did say it looked like black smoke dust. I really don't dump the pedal and run wot. Just cruise around mainly, sometimes I'll give her some gas but it's not a wot throttle like today.
Nhurt is offline
post #4 of 15 (permalink) Old Jun 17th, 15, 09:47 PM
Steve69SS396's Avatar
Try some smaller accelerator pump squirter nozzles. Your Air/Fuel ratio is rich on hard acceleration. Smaller squirters should clean that up and make it run even harder.
Steve69SS396 is offline
post #5 of 15 (permalink) Old Jun 17th, 15, 10:00 PM Thread Starter
Nate
I'll have to see what size the nozzle is on it now. One step smaller you think? I'm going to try a couple more wot runs one after another to see if it's just carbon in my exhaust before I try out the nozzle swap.
Nhurt is offline
post #6 of 15 (permalink) Old Jun 18th, 15, 09:00 AM
mike
Don't mess with it if it is running well, likely it is just [email protected] in the exhaust.
bigblockragtop is offline
post #7 of 15 (permalink) Old Jun 18th, 15, 09:05 AM Thread Starter
Nate
Thanks!
Nhurt is offline
post #8 of 15 (permalink) Old Jun 18th, 15, 09:42 AM
George
Gbauer's Avatar
You can try going one step smaller.
Here's what I'd do: Read the plugs.
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #9 of 15 (permalink) Old Jun 18th, 15, 12:14 PM
Fred
Yep, don't mess with it.
128.79mph 1.428 60'
Fred Ficarra is offline
post #10 of 15 (permalink) Old Jun 19th, 15, 09:10 AM Thread Starter
Nate
The plugs look great. I'm not going to mess with it, it runs great and probably just carbon that puked out from the exhaust when I dumped it.
Nhurt is offline
post #11 of 15 (permalink) Old Jun 19th, 15, 06:56 PM
mike
yup and you know what that means..... You don't step on it enough!
When in New York we called it an Italian tuneup(please no one take offense geeeeze).
post #12 of 15 (permalink) Old Jun 19th, 15, 08:39 PM Thread Starter
Nate
Hahahahahahah
Nhurt is offline
post #13 of 15 (permalink) Old Jun 19th, 15, 09:01 PM
Kev
Hahahahahahah
x2
67sc is offline
post #14 of 15 (permalink) Old Jun 21st, 15, 12:29 PM
Fred
Originally Posted by 67sc View Post
x2
So that's where that came from, New York. I thought it was from my neighborhood. Oh wait. I was in New York once too. It was 67 years ago.
128.79mph 1.428 60'
post #15 of 15 (permalink) Old Jun 21st, 15, 01:55 PM
Anne
Since it's "make fun of Italians day" :
The Italian Tomato Garden
An old Italian man lived alone in the country. It was Spring and he wanted to dig his tomato garden, as he had done every year, but it was very hard work for the aging man as the ground was hard. His only son, Vincent, who used to help him, was currently in prison. The old man wrote a letter to his son and described his predicament:
Dear Vincent,
I am feeling pretty bad because it looks like I won't be able to plant my tomato garden this year. I'm just getting too old to be digging up a garden plot. If only you were here my troubles would be over. I know you would dig the plot for me.
Love Dad
A few days later he received a letter from his son:
Dear Dad,
Not for nothing, but don't dig up that garden. That's where I buried the BODIES.
Love,
Vinnie
At 4 a.m. the next morning, FBI agents and local police arrived at the old man's house and dug up the entire area. However, they didn't find any bodies, so they apologized to the old man and left.
That same day the old man received another letter from his son.
Dear Dad,
Go ahead and plant the tomatoes now. That's the best I could do under the circumstances.
Love,
Vinnie
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
