New motor has finally arrived. - Team Camaro Tech
post #1 of 7 (permalink) Old Jun 18th, 15, 01:35 PM Thread Starter
Andy
I bought this car 3 years ago as basically a shell. It had a non running 350 from what I was told. Did the usual work and got it running and driving. A few weeks later the motor lost cyl 5/7. Ugg. So I tore into it and discovered that it was only a 305. Well I yard that turd out and do a quick 350 swap I had picked up off CL. Drove it for about a season and noticed it was starting to oil pressure issues. Just my luck... found that the block was cracked and coolant was filling the oil pan. Due to a lack of funds I parked the car since last July and started looking into a brand new motor. It took a little while to settle on something and a little convincing of the wife. In April I was finally able to order a brand new 383. It took a long 2 months of waiting but it finally arrived on Monday.
Bgcj5 is offline
post #2 of 7 (permalink) Old Jun 18th, 15, 01:45 PM
Andrew
Andrew69's Avatar
Re: New motor has finally arrived.
Sweet!!
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #3 of 7 (permalink) Old Jun 18th, 15, 01:56 PM
Chris
I recognize that yellow tape!!!!
Chris
cstraub is offline
post #4 of 7 (permalink) Old Jun 18th, 15, 02:13 PM Thread Starter
Andy
We all know that I can't post that and then not post some specs. 383 stroker, aluminum heads with 200cc runners, 2.02/1.60 stainless valves, Scat 9000 Series Crank, forged pistons, 6 inch rods, 10.5-1 compression,VALVE LIFT WITH 1.5 ROCKERS : INT .530 / EXT .545
DURATION IN DEGREES : ADVERTISED - INT .286 / EXT .294
DURATION @0.050" : INT .233 / EXT .241
LOBE SEPARATION ANGLE : 110, dual plane intake and quick fuel 750 carb
The firstt dyno pull it was 462hp with 468 lb/ft. The finial pull was 480hp with 474 lb/ft. The company said it ran very strong and compared to other dyno's their numbers are usually 20 hp below others. So the motor may in fact be 500 hp. I'll be installing it this weekend hopefully all goes well.
Bgcj5 is offline
post #5 of 7 (permalink) Old Jun 18th, 15, 02:52 PM
George
Gbauer's Avatar
Next you're going to be buying new tires...
Sold:
Offy intake
Holley 390 CFM carb
Mild cam
Custom interior
Gbauer is offline
post #6 of 7 (permalink) Old Jun 18th, 15, 08:47 PM
Looks good and familiar. Skip White?
f350power is offline
post #7 of 7 (permalink) Old Jun 18th, 15, 09:52 PM
mike
SO happy it is not an LS. Looks great!!!
bigblockragtop is offline
