396 timing - Team Camaro Tech
post #1 of 28 (permalink) Old Jun 18th, 15, 03:09 PM Thread Starter
DT
Donny
DT's Avatar
396 timing
Finally getting around to timing my engine. What are you guys using for timing on your 396 ? Just curious. I started out 12 initial, 34 total.
DT is offline
post #2 of 28 (permalink) Old Jun 18th, 15, 07:00 PM
Tom Anderson
Re: 396 timing
I do it the old fashion way and power tune it by ear. Bring it up to about 3500 move the distributor till you hit the sweet spot and then back off just a little. The car runs great and starts easy . If it turns over slow retard it some, works every time for me
socal_tom is offline
post #3 of 28 (permalink) Old Jun 18th, 15, 08:09 PM
mike
Re: 396 timing
Back then we could get away with timing by ear, that was when gas was good quality and better octane. Detonation will destroy an engine. Big blocks like timing, you can get away with 36-38 total but will have to listen for detonation and check plugs for metal specks. What is the compression ratio? Cast heads or aluminum?
bigblockragtop is offline
post #4 of 28 (permalink) Old Jun 19th, 15, 06:36 PM Thread Starter
DT
Donny
DT's Avatar
Re: 396 timing
Aluminum heads 9.75 to 1 compression, thanks for the replies.
DT is offline
post #5 of 28 (permalink) Old Jun 19th, 15, 08:45 PM
Nick
Rarerat's Avatar
Re: 396 timing
I run mine with 18 initial & 36 total all in by 2500rpm.
Rarerat is offline
post #6 of 28 (permalink) Old Jun 20th, 15, 04:28 AM Thread Starter
DT
Donny
DT's Avatar
Re: 396 timing
Thx Nick
DT is offline
post #7 of 28 (permalink) Old Jun 20th, 15, 05:42 AM
Doug
Re: 396 timing
What are the specs. on your camshaft. Did you measure the quench and what is the thickness of your head gaskets. What distributor are you using? Finally are you running a 4 speed or automatic transmission?
Cdminter55 is offline
post #8 of 28 (permalink) Old Jun 20th, 15, 06:08 AM Thread Starter
DT
Donny
DT's Avatar
Re: 396 timing
DUI dizzy, 4 speed,
cam specs: duration @ .050 229/235
LIFT .585/.585
LSA 110
INT C/L 106
DT is offline
post #9 of 28 (permalink) Old Jun 20th, 15, 11:41 AM
Anne
Re: 396 timing
Originally Posted by DT View Post
DUI dizzy, 4 speed,
LIFT .585/.585
LSA 110
INT C/L 106
What vacuum advance can are you running ? Your combo should have about 12" vacuum at idle.
Be sure the can is fully advanced below the idle vacuum.
Government's first duty is to protect the people, not run their lives.
Ronald Reagan
Lawrence454 is offline
post #10 of 28 (permalink) Old Jun 20th, 15, 12:47 PM
Fred
Re: 396 timing
Drat! I was hoping to help out. Oh well. But wait! Here's how the factory said to do it on mine.
128.79mph 1.428 60'
Fred Ficarra is offline
post #11 of 28 (permalink) Old Jun 20th, 15, 02:26 PM Thread Starter
DT
Donny
DT's Avatar
Re: 396 timing
No vacuum advance.
DT is offline
post #12 of 28 (permalink) Old Jun 20th, 15, 05:38 PM
mike
Re: 396 timing
You realize you will catch some grief for no vacuum advance... I run mine locked at 36 and pull timing back under boost(my ignition turns back timing when starting). A proper vac advance really is best but without one you will need to run as much initial as you can and max out at 36. If you can run a really small amount of mechanical advance that would be best. You can run it locked like me but having a start retard will be your starters friend. Or an ignition kill switch, let it spin without spark and then let go of the kill.
post #13 of 28 (permalink) Old Jun 20th, 15, 09:03 PM
Anne
Re: 396 timing
After all of these years I finally find the right instructions !
Ronald Reagan
post #14 of 28 (permalink) Old Jun 21st, 15, 12:25 PM
Fred
Re: 396 timing
Did you see the 4 in red at the bottom? That's initial. There is not a missing digit in front of it. Can you imagine timing a BBC with 4 initial?
128.79mph 1.428 60'
post #15 of 28 (permalink) Old Jun 21st, 15, 04:25 PM Thread Starter
DT
Donny
DT's Avatar
Re: 396 timing
Yes I know regarding the vacuum advance. My DUI has 22* in by 3,000. I think I will set my initial at 14* then. I'm currently at 12 initial 34 total.
Thx
DT is offline
