Engine suggestions....taking out the original dz 302 - Team Camaro Tech
post #1 of 37 (permalink) Old Jun 18th, 15, 07:15 PM Thread Starter
Hi all,
I wanted to take out my original dz 302 from my 69 z28 for safe keeping and replace it with another sbc engine. The only thing stipulation is that it looks like the original dz motor (hump heads, winters intake, mechanical fuel pump,etc). This car will not be raced but just for spirited driving, cruise nights, and car shows. I know I can have dart iron heads altered to have the double humps but other than that I'm open to engine suggestions. I do have (2) 140 offroad cams laying around to use but don't have to use them in the replacement motor.
xxxg00w0pilot is offline
post #2 of 37 (permalink) Old Jun 18th, 15, 07:38 PM
Smile Re: Engine suggestions....taking out the original dz 302
Well in my opinion, you are limiting yourself to a 350 cid with those heads.
TJS69 is offline
post #3 of 37 (permalink) Old Jun 18th, 15, 08:09 PM
Vega$69's Avatar
Why not keep the 302 in it and enjoy it for what it is.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 37 (permalink) Old Jun 19th, 15, 12:06 AM Thread Starter
I was hoping using the dart heads might have given me more options.
post #5 of 37 (permalink) Old Jun 19th, 15, 12:07 AM Thread Starter
I'm too paranoid to use the 302 as it was designed
post #6 of 37 (permalink) Old Jun 19th, 15, 01:18 AM
Yes, with different heads ( just paint them orange like the block) you could build a very nice 383 !
TJS69 is offline
post #7 of 37 (permalink) Old Jun 19th, 15, 04:20 AM
Kevin
KevinW's Avatar
You could still make a 383, you just need to dish the pistons to keep the CR down when using the 186 heads. Get an internally balanced kit and an older large pad block and you would not notice the difference. Of course power would not be the best it could be when using the heads and factory exhaust manifolds. But it would have more TQ than you have now.
Kevin
KevinW is offline
post #8 of 37 (permalink) Old Jun 19th, 15, 04:37 AM
Chris
Originally Posted by xxxg00w0pilot View Post
Hi all,
4.125 x 3.25 stroke. Nothing but fun!
Chris
cstraub is offline
post #9 of 37 (permalink) Old Jun 19th, 15, 05:03 AM
I like Chris' idea. The car should have fairly low gearing (if it still has the original rear end), so may as well take advantage of it and build an engine with the same basic stroke/bore ratio as the original.... all while gaining 45 cubic inches over the 302.
buenymayor is offline
post #10 of 37 (permalink) Old Jun 19th, 15, 05:28 AM
Bruce
How about a 350 built to 70 LT1 specs. I did that with my 69 vert and it is awesome!
The Camaro Guy is offline
post #11 of 37 (permalink) Old Jun 19th, 15, 06:07 AM Thread Starter
Thanks for the ideas. Car has the original rear end and 3.73 gears. I like the short stroke large bore motors but also like the big cubic inch small blocks but realize the stock heads doesn't flow well.
post #12 of 37 (permalink) Old Jun 19th, 15, 07:15 AM
Vega$69's Avatar
SBC 400 would be my choice. Paint the heads orange correct valve covers etc to keep the original look.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #13 of 37 (permalink) Old Jun 19th, 15, 07:35 AM
SBC 406 with a set of seven rib valve covers with the oiler nibs ground down to clear the short poly lock nuts on top of your roller rockers and a set of AFR heads that have been put in a CNC mill to replicate your existing head's identification casting marks.
I wouldn't even pull and modify your valve covers instead using a set purchased used of line.
Big Dave
Larger Dave is offline
post #14 of 37 (permalink) Old Jun 19th, 15, 07:47 AM
Cool Re: Engine suggestions....taking out the original dz 302
I really don't understand the thinking that goes on about these cars. You either buy them to enjoy or you put them in a trophy room and never touch them. My thinking is, you only live once so why not enjoy it cause the next guy will after your gone. I know guys who hammer these original cars at The Mid Mich 1/4 mi track for the all stock drags each yr. Get out there and enjoy what you have rather then saving it for the next person. My .02.
COPO is offline
post #15 of 37 (permalink) Old Jun 19th, 15, 08:06 AM
Chris
When you add stroke you add piston speed. As piston speed goes up so does the demand on intake track and exhaust track. By increasing the stroke to 3.25 and going big bore you will be able to use the induction and exhaust manifolds originally designed for these cars while still maintaining the "Vintage Sleeper Look".
Yes a 383 and 406 are more CID but they require bigger stuff to let them breathe. The short stroke engine will still make power to the rpm where the 3.73 gear wants to go.
If this is a play engine then go 4.185 x 3.25 with a 6.250 Long rod. This will give you a 358CID power plant an I will promise you......more tire smoke than you can shake a stick at!!!!!!
Chris
cstraub is offline
