engine compression? - Team Camaro Tech
post #1 of 8 (permalink) Old Sep 20th, 04, 06:16 AM Thread Starter
im trying to figure out what my compression is. heres a list of componets i have.
383 stroker
chevy heads-462624-76cc chamber, 1.94/1.5 valves
5.7 in rods stock rocker arms
comp cam 270h- 270 degree .470 lift
pistons-Silv-O-Lite SB-Chevy Hypereutectic Pistons 5/64'', 5/64'', 3/16'' ring grooves
intake - torker 2
scat 383crank... i have finally got this running and was trying to guess what the horsepower is about also.. thanks for any input.. [img]graemlins/clonk.gif[/img]
i am the bad things that happen to good people!<br />86 iroc 383 stroked and charged...
stuckinablizzard is offline
post #2 of 8 (permalink) Old Sep 20th, 04, 11:11 AM
We need a little more info. Part number of pistons, std. bore or +.030 - +.060. Head gasket thickness, deck height, were the heads milled, etc.
69 RS 355 Tremec 5-Speed 4.11's
12run is offline
post #3 of 8 (permalink) Old Sep 20th, 04, 11:12 AM
lol... ya, for the guys with the calculator spreadshhets.... it'll be around 8.5 or 8.75:1
post #4 of 8 (permalink) Old Sep 21st, 04, 05:49 AM Thread Starter
lol thanks jim...the heads were milled but it was almost 2 yrs ago and i dont remeber the specs..bore is 30 over 2 valve relief flat top 1.560" compression height std head gasket from fel pro gasket set.
post #5 of 8 (permalink) Old Sep 21st, 04, 08:15 AM
Unhappy
Can't get nothing but a guess if you don't have a good idea what cc the head chambers are, imho...
pdq67
post #6 of 8 (permalink) Old Sep 21st, 04, 09:58 AM
lol paul, that's exactly what i gave em...
post #7 of 8 (permalink) Old Sep 22nd, 04, 12:01 PM Thread Starter
post #8 of 8 (permalink) Old Sep 22nd, 04, 04:00 PM
The ROSS Racing Pistons site gives 9.39 to 1 CR. using a .039" thick composite headgasket, -4 cc's for valve reliefs and .025" down in the hole piston height..
A Fel-pro, PN 1094, .015" shim headgasket puts you at 9.87CR. which should very good for pump gas, imho...
A 750 carb, single plane, stock, medium valve heads, (pocket-ported), and open small headers gives about 388hp at 5,000rpm and and 453/454t between 35 and 4,000rpm figuring the 9.39 CR.
The 9.87 CR. number gives 398hp at 5,000rpm and 463t at 4,000rpm.
A nice mild motor, imho...
pdq67
